I have Casio, Japan make MJ - 120 Model calculator. Percentage functions are not working properly. For example: 200+20%=240. But my calculator shows 250, likewise 200-20%=160, but it shows 900. Please help me out.
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
For Calculating percatnge and then adding it to the principal you ought sequence the keys for your above example, in the following manner:
Key in 200 : Display shows 200
Press X : Display shows 200 *
Key in 20 : Display shows 20
Press % : Display shows 40
Press + : Display shows 240
Similarly for the later part of example,
Press - : Display shows 160
So, first multiply, with the value of %, then instruct the calcy that the value was a % value & then deduct or add to the principal as desired.
How do I set tax rate in casio mj-120t
I think the software in your casio is corrupted. return it to the dealer and get a new one.
Look for a key with "RATE SET" printed above it and press and HOLD that for about 3sec then type in the tax rate using number keys. Then press RATE SET key again.
On my Casio MJ-120TG it is the % key which has this dual function.
Please suggest me whats the solution
Press + : Display shows 40 Instead of 240
In answer to original question. I get your answer on my MJ-120T if I type 2 0 0 MU 2 0 % in other words what price do I sell at in order to have 20% mark up when buying for 200. Answer 250 as the mark up is on the final price (20% of 250 is 50 so correct).
To simply add 20% to a value key the following>>
2 0 0 + 2 0 % to display 240.
Or like this to see the intermediate percentage calculation>>
2 0 0 x 2 0 % to display 40 and then + = to display 240.
Or on the MJ-120 you can set your TAX rate to 20 and just use the TAX+ and TAX- keys this model has these dedicated keys.
I bought a Casio Fx-991ES. Few days ago i noticed that my display line is inverted. I dnt know what function i pressed. Please help me... For Example.... Before when i press 5 it shows in 1st line... Bt nw its in 2nd line and its inverted 5
How can i fix my problem?
the calculator is not turning on. pls help
