Lands Phones Logo
Posted on Mar 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Partner 18d display problem AVAYA
Customer called and says several of their partner 18d phones have problems with the display. The problem is described as parts of the letters in the display do not display. These phones are about 1.5 yrs. old. I suggested adjusting the display but that didn't seem to help. Do you have any suggestions? Is this a ksu problem or indiviual phone problem? Sounds strange that several of the phones are doing the same thing.
  • tpedigo Mar 12, 2009
    Thanks,
    I will try that when I get on site today.
formulacoop
Level 2:
  • Expert 43 Answers
  • Posted on Mar 12, 2009
formulacoop
Expert
Level 2:
Answers
43
Questions
Helped
30459
Points
138
Power the system off and after about 10 seconds power back on. This usaully clears the problem. Let me know if there is still an issue.
My avaya partner 18d phone does not ring how can I turn on my ringer
Hello Tom,
Avaya actually has SEVERAL "PARTNER"
models referred to as 18D... but when I was associated... they WELCOMED CUSTOMER CONTACT opportunities in the
continental U.S. ... call their toll-free Heipline,
available 24 hours a day, at 1 800 628-2888.
You should first check your owners manual...
The most likely cause:
is the "DND" (do not disturb) Feature is "ON".
If you books are not immediately available AVAYA customer support can assist your EVERY COMMUNICATIONS NEED.
For free manuals check out the URL (link) below...
If you are still stunned (a lot of buttons) comment me back with the EXTRA 3 characters in the name... and I'll look up your precise model.
Results 1 10 of 10
15helpful
How do I Change Tine on a AVAYA PARTNER 18D Phone?
Press Feature 00 (zero, zero) from station 10 or 11. Press left intercom button twice, press #103, and then enter time in military format (24 hr). Press feature 00 again. This is all done with the handset down.
Avaya 18D phone only speaker works not the handset. Order a replacement phone and the new phone does the same. We swapped locations snd the problem goes with the phone. Handset placed on a known working...
Avaya Partner 18D Button phone:
Two possible solutions,
First, could have a bad handset cord.
Second, I have come across a bad handset connection ports on the Euro style phones. The handset cord and the port just don't mesh well or the port itself is bad.
Phone static on the partner 18d
Is it on the same line? What about when you call other extensions, is there static?
If it is a line, swap that line and another. If you have static on the same line port, then it is a port problem of the system. If it follows the dialtone, the line from the phone company is the problem.
1helpful
Partner-18D (lucent avaya phone)on the display it
Get yourself 2 alkaline AA batteries, keep the power on, and look for the door on the lower part of the face on the ACS processor module. Pop the cover and replace the batteries.
Carl
1helpful
2answers
I have a customer that has lost the display on 5 of 14 partner 18D phones purchased in 2007 any suggestions?
Call your distributor. I dont remember hearing anything about a bad batch. I think Partner phones only have a 1 year warranty, but maybe it is longer....
Partner 18d caller id checking
It should say "Calls" on your display. If not, the caller ID log is not set up.
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Press feature "00" to logout
Hope that helps
1helpful
Partner 18D not ringing, just beeping
The phone is forwarded.
At that phone, press feature 11, XX, XX
Where the XX's are is that extension number. So if it was extension 12:
Feature 11, 12, 12
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Top Avaya Lands Phones Experts
NOEL
NOEL
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
