I have my prepaid unit of motorola ex-119, i am trying to top up, but whenever i press the refill syntax, it will have error "for emergency call only", but then i can call other number, i just can't refill my load balance. how to settle this - for emergency all only message. have i unknowingly press any wrong settings?please help
SOURCE: whenever i try sending a text message, it always sends as a picture message
hey i was having the same problem, seemed to occur when cingular switched over to att, i resolved this problem by deleting all messages. when you are in the message menu select options then cleanup mesages and select all messages. hope this works for you as it did me. good luck!!
SOURCE: Unlock the NET 10 prepaid Motorola W 375
I am having one motorola w 375 i brought in singapore now in can"t able to use this phone the service provider (T-mobile) will lock this phone please help to unlock
SOURCE: unlock prepaid cell phone motorola c168i
find att customer service number and demand the unlock code theyll ask for your imei then give you one
SOURCE: my motorola is showing `` no service and emergency calls only ``
it has to be bad reception....have u tried contacting ur netwrk service provider...plz do check with them and update me...
Thanks for using Fixya!
tc
SOURCE: motorola rokr e8 error message
not even a MASTER RESET will resolve this issue most of the time. the only way to fix it is to perform a MASTER CLEAR. Before doing a master clear, make sure you save all contacts to your sim card and images, videos, etc to your memory card.
