Knowledge Adventure Teletubbies 2: Favorite Games Logo
A
Anonymous Posted on Apr 11, 2013
Teletubbies 2 and windows 7 - Knowledge Adventure Teletubbies 2: Favorite Games
davydalbah28
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 30, 2018
davydalbah28
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
113
Points
2answers
How to reset window 7 password for free
How to <a href="http://www.recoverlostpassword.com/article/unlock-win7-password.html">unlock Windows 7 password</a> when you <a href="http://www.recoverlostpassword.com/article/forgot-windows-7-password.html">forgot windows 7 password</a>? Try to make use of <a href="http://www.recoverlostpassword.com/products/windowspasswordrecovery.html">SmartKey Windows Password Recovery</a>.
Step 1: Obtain Windows Password Recovery tool
Step 2: Create a Windows 7 security password totally reset computer
Step 3: Totally reset forgotten password Windows 7
tip
How to enable Windows 7 administrator account and reset lost Win 7 admin...
How to enable Windows 7 administrator account and reset lost Win 7 admin password
There are two parts for your Windows 7:
* Enable Windows 7 administrator account
* Reset lost Win 7 admin password
With 240 million licenses sold out in one year, Windows 7 has been proved to be a successful product of Microsoft. Compared with its previous versions like Windows XP, it has many improved features. The built-in administrator account is one of the features. In Windows XP, there is a default administrator account after installation. But the built-in administrator account is disabled by default in Windows 7. To enable Windows 7 administrator account and assign a password to it, you can achieve it in 2 methods.
Part I: Enable Windows 7 administrator account
Method 1: Use Command Prompt
The easiest way to enable the Windows 7 built-in administrator account is to use the Command Prompt.
1. Click Start and type CMD in the search box. Right-click CMD and select Run as Administrator.
2. Click Yes when prompted to allow the Command Processor to run. And then the command prompt will appear.
3. Type net user in the command prompt window, and then hit Enter. All the Windows account user names will be listed. You'll also see the Administrator account, but now it is not enabled.
4. Type net user administrator /active:yes and hit Enter to enable Windows 7 admin account.
Now the Windows 7 administrator account is created. To create the Windows 7 administrator password, you can follow the below steps:
1. Switch to log on Windows 7 with the administrator account.
2. Click Start, Control Panel, User Accounts and Family Safety and User Accounts in order. You'll enter the screen where you can make changes for your account.
3. Click Create a password for your account on the screen.
4. In the coming screen, type and confirm your Win 7 admin password.
5. Enter password hint and click Create Password.
Now your Windows 7 admin password is successfully created.
Method 2: Use Local Users and Groups
1. Click Start and type lusrmgr.msc in the search box, and then hit Enter. The Local Users and Groups screen will come up.
2. Double-click the Users folder. And all the Windows 7 account will be displayed for you.
3. Right-click the Administrator account and select Properties.
4. Uncheck the "Account is disabled" check-box and click OK on the administrator properties screen.
Now Win 7 admin account is enabled. To set a password for the enabled Windows 7 administrator account, follow the steps as below:
1. Right-click the Administrator account and select Set Password.
2. Click Proceed to go on your operation
3. Type and confirm your new Win 7 admin password and click Ok
4. Close the Local Users and Groups screen.
Now the Windows 7 administrator password is assigned to your Windows 7 admin account.
Part II: Reset lost Win 7 admin password
Windows 7 administrator password reset Tips:
Note 1. Please remember to create a Windows 7 password reset disk after assigning Windows administrator password. It allows you to change your forgotten Win 7 admin password when you are locked out of Windows.
Note 2. If you forgot to create the password reset disk, you can choose to use Windows Password Breaker to help create a Windows 7 password reset disk rather than reinstalling the system. Now follow the steps to create the disk to reset Windows 7 password.
step 1. Download and install Windows Password Breaker.
step 2. Run the program and burn a Windows password reset disk.
Step 3. Reset Windows 7 administrator password with the disk.
It is an easy and safe way for Windows 7 admin password reset.
on Nov 02, 2010 • Computers & Internet
tip
How to Change or Remove Windows 7 Password?
Windows 7 allows you to create a strong Windows 7 password to protect your data on computer. Meanwhile it also provides you solution to change or remove Windows 7 password. So you are able to change Windows 7 password if you forgot Windows 7 password or intend to reset Windows 7 password for other reasons. Here are guides on how to remove or change Windows 7 password.
Solution 1: Change or remove Windows 7 password through Windows 7 control panel
If you can log on your computer with Windows 7 password, you can remove or change Windows 7 password easily through Windows 7 control panel.
To change Windows 7 password, please follow the steps:
Step 1: Click on Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Change your password.
Step 3: In the screen comes up, type your current password, the new password you would like to start using and a password hint. (password hint is optional)
Step 4: Click Change password button to confirm your Windows 7 password change.
Now your Windows 7 password has been changed, and you must use your new password to log on to Windows 7 from this point forward.
To remove Windows 7 password, it is also very simple. Just follow the below steps:
Step 1: Click Start > Control Panel > User Accounts and Family Safety > User Accounts.
Step 2: Click Remove your password.
Step 3: Type your current Windows 7 password in the text box on the following screen.
Step 4: Click Remove Password button to confirm that you'd like to remove your Windows 7 password.
Now your Windows 7 account password is removed. And you will no longer need to log on your computer with Windows 7 password.
Solution 2: Remove Windows 7 password with Windows Login Recovery
If you are locked out of computer as you forgot all Windows 7 passwords, what should you do to remove or change Windows 7 password then? At that time, you need the help of Windows password recovery software to remove your lost or forgotten Windows 7 password. Windows password recovery software allows you to remove lost or forgotten Windows administrator password, standard user password on all popular Windows OS, including Windows 7. By burning a bootable CD/DVD or USB flash drive, you can easily regain to computer again.
Here are the steps to remove Windows 7 password with Windows Login Recovery Professional:
Step 1: Download Windows Login Recovery Professional and install it in any computer.
Step 2: Run the program and burn an ISO image file into the blank CD/DVD or USB flash drive.
Step 3: Start your locked computer from the bootable CD/DVD or USB flash drive.
Step 4: Remove Windows 7 password by following the instructions.
And now you can access to your computer without password. And you can easily remove or change Windows 7 password according to the steps in solution 1.
Of course, you can also change Windows 7 password if you have a password reset disk in advance. If you don't know how to create one, You could follow the guide of Microsoft's official website.
on Oct 14, 2010 • Computers & Internet
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Repeat
Using the remote control, try pressing play twice. A menu may appear indicating to repeat once or continuously.
WARNING Using this mode in conjunction with TeleTubbies has been known to cause insanity.
Halo 2 Windows 7
Halo 2 not yet compatible with windows 7, may be soon compatibility pack will release for this game.
Lost instructions for bubble console pre school game
hi tim im having some problems with bubble at the moment its unreal i have some phillips codes dont know if they will work however ill give them to you anyway
0503 0539 0646 0671 0675 0854 0885 1158 1260 1267 1812 1813 1818 1911 1914 if you stick the set up dvd in n watch the first time set up bit it explains everythin you need to know i there hope this helps you out!
Dec 20, 2008 • Toys
Red is no longer showing.
Well if there is orange I would think you lost your green. My question is this point are all three tubes lit up. That would give me clue what direction to send you in.
Top Knowledge Adventure Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Knowledge Adventure Video Game Console and Game Expert? Answer questions, earn points and help others
