When i turn on my GT5654 desk top PC.all i get is a beeping sound and a black screen.what can i do to fix it?
SOURCE: "I turned on my PC Gateway 610 and the top of the screen is dark"
you can fix it without paying any thing just tell me whats the problem,.. wish luck to you
SOURCE: my desk top will not turn on the green light at
Replace the power supply.
Apparently you are getting power to that, but it is not passing power to the motherboard.
If this does not work, I would suggest the following for troubleshooting:
Open the case and unplug everything but the memory (hard drive, CD, other cards)
Now try to start it. If it starts, it's probably the CD.
If, with only the CPU and memory plugged in, nothing happens, then it's probably the power supply.
The next step would be to replace the motherboard.
SOURCE: I don't know how to turn on wireless radio adapter
It should either be in the settings for the card, (software) the control panel around network connections or the card on device manager.
SOURCE: Gateway Gt4022 PC Desktop
Try a different monitor (borrow one). If that doesn't work, you need to take it to the shop.
