Our Panasonic Viera tv won't turn on. We have unplugged it over night. It was working fine and then after having the tv for 24 hrs it just shut itself off and when we try to turn it on it comes on with a set up menu and whatever channel the cable is set to and stays on for about a second and then the screen goes black and the power button flashes red. We have tried holding the power button down for a couple of seconds and that doesn't help either. Any other help would be wonderful!!! I was playing the wii and had to pause it for a couple minutes. Then I was getting ready to go back to the wii and the TV shut itslef off. :( the TV is was built in april of 2006. Any ideas?
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
the problem for 7 blinks is an Interface board. Had mine fixed yesterday. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. They replaced the board with a new one and updated the software on the new interface board. It works like new and i couldn't be happier to be watching it again. Hope this helps everyone else out.
