Where can I get power cord for norelco 5801 xl shaver>
Power cord adapter norelco 5801xl is charging replacement is norelco 74-C20 charging power cord replacement.
http://www.menelectricrazor.com/norelco-5801xl-charger
Power cord for model 5801XL can be found at shaveroutlet.com
Universal Shaver Cord Coiled for Most Models
SOURCE: Norelco shaver service centre in India
i am based at hyderabad india and wish to get my norelco shavers modelno4852XL and 7864 repaired is there any sevice centre in hyderabad andhrapradesh india
please email me on [email protected]
SOURCE: How do you change the batteries in the Norelco
Start by removing the two screws on the back and remove the back cover. You will then be able to see the batteries. They are soldered to the back side of the circuit board. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries for model 5801XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
If you are not able to do this yourself, shaveroutlet.com can do it for you. See information link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
SOURCE: Electrical specs for Norelco 5810 XL shaver
Yes. It has the universal power supply. You will need the country adapter, but it will run on 240v. So says the support center at Phillips.
SOURCE: how do I change the
Most Norelco shaver models require soldering the battery pack in place.
Keep this in mind before attempting to replace the battery. If you do
not have experience disassembling electronics, you might take it to a professional for assistance.
Thing you will need to perform this task would be; a mall soldering pencil (3/2" 700 or 800 degree tip), screwdriver and electronic side cutters.
Carefully follow the steps below;
Purchase the replacement shaver battery pack that will accommodate the
5801 XL model. A number of models use the same battery pack and would
follow the same instructions. The Norelco 5801 XL requires a 1.2V 600mAH
battery pack with soldering tips. This battery pack has several
applications besides the Norelco Shaver, allowing it to be found easily
in your local electronics store or online.
Detach the back plate off the Norelco razor by using the screwdriver and
removing the two screws that hold it together. This will expose the
battery pack.
Locate the two spring clips that hold the battery pack in place. Push inward and then up to unlatch spring clips
Clip the old soldering tabs with electric side cutters to remove the old
battery pack from the shaver. Do not attempt to salvage the old
soldering tabs. Resoldering the old metal tabs might damage the PC
board.
Bend the new battery pack leads into a "V" shape so they match up
against the old leads of the PC board. Once aligned, push down on the
battery to snap it into place.
Solder new leads to old leads with the soldering pencil.
Snap the two spring clips back into place and reattach the back panel.
Charge the new battery pack. Once completely charged, turn on the Norelco 5801 XL to test.
I hope the above instruction helps.......
Good luck.
SOURCE: Battery appears to be dead..
Norelco 5885xl repacement rechargable batteries is norelco shaver battery replacement.
