May 27, 2018 - my konka smart tv is stuck on smart tv loading doesnt go further - Televison & Video. ... check the site linked here. Pull up older posts. ... My TV Konka LED TV KDL55XS712AN is not starting and saying: LOADING... Corrupted ...
Sep 2, 2016 - Konka LED TV KDL55S712AN has refused to start and is staying in the screen on" Smart TV loading..." ... Then on the actual TV, hold the power button for 60 seconds then release. Then wait 10 minutes, connect the power again to the TV, turn it on and tell me please if it is now operating correctly.
1 answer
Restart The Device. This is the first step in troubleshooting an Android device that won't boot past the startup screen. If this has not been done, it ...
hi, better u purchase an universal remote, and program it for ur tv.philips magnavox universal remote can be used to control ur tv by entering any one of the following code
Check soldered in fuse R607 in power supply circuit =
If open, replace it and bad converter xistors ( 2SC4834)
Next, replace shorted horizontal output transistor w/ first Quality.
Solder any / all bad connects,esp.horiz drive to base of horiz.
o / p xistor. Soldering is critical or it will blow up again......
some times it is due to channel interference or due to weak signal or poor transmission.
as your tv is perfectly ok so question of defect in tv.
it is outside problem only please check it.
replaceing parts will not solve your problem.
you will have to go as per procedure.
solution
check power supply output.
if it is ok check horizontal section.
