Whirlpool awo3561 fault showing as f06? what does that mean. it wont spin.
"F06" is a Motor Speed error code. It means the motor is not spinning, or you have a loss of commuincations between the Motor Control Unit (MCU), Central Control Unit (CCU) or Drive Motor. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The easiest place to start would be to verify all your connections between the Drive Motor and MCU are intact and not corroded. Then, perform resistance checks on the Drive Motor windings.
For ease of troubleshooting, UNPLUG the washer and remove the top panel by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off. Position the washer where you have full access to the rear. Remove the back panel of washer. With the top and back removed you will have full access to the CCU, MCU and Drive Motor.
If you have questions along the way, or if you require addtional assistance, please let me know. I hope you find this information helpful.
Hi Mr. Been Help me :)
The large burner element on my GE JP670 electric cooktop would come on and off intermittently. Sometimes it would not come on at all. Other times after it came on and was heating the food it would go off. I replaced the burner element, but it still does the same thing. If the problem is the infinite switch. Where is it located in the cooktop and how do I replace it?
