Samsung PS42P2S 42 in. Plasma Television Logo
Anonymous Posted on Apr 02, 2013
Samsung PS-42C7S, have audio but only flashing white noise on picture.
Have a 2006 Samsung PS-42C7S. Screen constantly flashing at about 1/2 second rate picture shows mostly garbled white noise with some coloured pixel dispersed in between. There are large random areas of the screen which remain blank during each flash and this is not confined to the same area of the tube and changes with each flash. No visible picture from inputs. Audio/volume and channel-change all work fine with clear reception of audio tv signal. Menu does not appear on screen. Have opened the back to visually check for bulging caps, all seem to be fine on all boards. There is a constant high frequency ticking sound coming from the boards on both side of the tube and possibly also the power board (don't know what the side boards are called). Have tested DC voltage outputs from power board with DMM, VS and all other DC signals with no load attached are within specified range. Also tried DMM on AC setting to see if there was any unusual ripple getting through but only very low insignificant measurements were found. Would appreciate if someone could point me in the right direction in order to further isolate the problem area. Have no experience repairing Plasma TV's, although I do have a technical background and some basic electronics experience (have recapped several motherboards and LCD monitors in the past). Do not have CRO only DMM. Many thanks in advance. Regards, Tony.
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Apr 02, 2013
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008095
Points
237762
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2200 posts now. All are related to electronic equipment repair help.
  • Anonymous Apr 02, 2013
    Hi Kumar. Thanks for the advice. I managed to locate the problem. It appears that 2 of the IC's on the buffer board have burnt out. The 2 IC's in question are actualy hidden from view when you first open the TV as they are located underneath the side input area and are covered by a thin metal plate. As soon as I removed he plate to expose the entire buffer board it was immediately apparent that the 2 IC's were damaged with the casing burnt right through. I think it is a poor design feature of this TV that these chips are in a confined space under a metal plate which aids in retaining localised heat. The other IC's on the board are at least in an open area where air can easily flow through and help take away some of the heat build up. Anyway, given the price for a new board and the age of the TV it is not really worthwhile repairing it. Thanks again for your help.
5 Related Answers
Anonymous
  • Posted on Nov 19, 2008
SOURCE: sound no picture, which component is tcon board? where all audio/video/cable/hdmi plug in to?
I have LNS4692D. Returned from vacation, turned tv on - no picture. Tried turning tv off for 4 hours- nothing. Symptoms are: tv is on - no picture , just sound; menu doesn't show, volume bar doesn't show;E.Saving is working - the backlight is changing from lighter to darker.
Found this website and ordered T-con, otherwise known as the LCD panel driver board, p/n# Bn8101286a ( thanks premtech) from partstore.com for $124. Part number BN81-01286A A/S T-CON Board.
Installation:
1.Remove plastic cover. There is an arrow for each screw that needs to be removed. Make sure to unscrew pins next to VGA port. I've spent some time trying to figure out what else is holding the plastic panel until I found this pins.
2. Remove big metal shield in the middle of tv that is covering main components. This shield is being held by small black screws all around it.
At this point you will see cover of T-CON. Here is the picture
http://www.avsforum.com/avs-vb/attachment.php?attachmentid=118863&d=1220531321 (thanks ldac9). Do not attempt to remove that cover yet. Proceed with a next step
3.Remove metal panel that holds main components. Locate big chrome screws that have arrows pointing to them and unscrew them. Remove 2 more screws on the bottom of the panel that holds it together with a box for cables. At this point the main panel will be lose
4. Carefully start lifting the panel. You will see that there are connectors going from components on the panel to components on the lower panel and T-CON. Carefully unplug these components and raise the main panel.
5. Remove 4 screws that holds T-CON cover. Pull the cover so that T-CON is completely exposed. The cover is connected by thin alluminum , don't hesitate to pull it , but don't rip it out.
6. Once T-CON is exposed you will see 2 red ribbons. I've spent some time to figure out how unplug those from old T-CON board. Here is the suggestion. Don't try to pull it out. All you need to do is to lift small plastic lever that is part of a connector. Then ribbon can be slided out. If not sure what to do, see how this is done on the new T-CON. It has a principle of buckle on airplain safety belts.
7. Remove old T-CON and install new you.
8. Follow reverse order.
I've never fixed TV before , but this was totally successful project.
Anonymous
  • Posted on Feb 08, 2009
SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
Anonymous
  • Posted on Jun 08, 2009
SOURCE: Samsung Plasma 50" No Picture but have sound
BAD Y BOARD
KingDWS
Dave King
  • 1606 Answers
  • Posted on Jul 09, 2009
SOURCE: no picture
It sounds like the backlight is out. If you can see a faint image that changes then this is the case. You either need to send in for repair or replace. It can if you are lucky be a connection. You can try removing the video cable and try another source or cable.
Anonymous
  • 304 Answers
  • Posted on Apr 16, 2010
SOURCE: Hello, I have a Samsung LN-S4692D.
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
I have a Samsung HL-T6189s. While watch tv the picture goes away. I still have audio.
Back light problem. Check and replace the damaged components at the back light inverter circuit. Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Model LN52A550P3FXZA. Video and audio cycle on and off every 30 seconds or so. When picture switches off, the screen is filled with multi-color horizontal lines.
It is a common problem for this model, the problem is the main board. There are 2 Tantalum capacitors (C102 & C131) 47MF/10V, 1 Passive Voltage regulator KIA7805AF (IC300), 1 Step-Down Power Conveter IC MP2363DN (IC101) need to be replaced. If you do not have soldering skills, just order a new board.
How to fix an intermittent white screen on a Samsung television?
Ask them to replace the t-con board. It could be a defect one.Good Luck.
Serge.
4helpful
Hi, My SAMSUNG LE40R88BDX/XEU LCD 40'', isnt working! When you turn the TV on it sounds like someone is constantly turning it on and off with the remote, as its making a constant switching on and off...
It sounds like the power supply board has some bad capacitors that need to be replaced. Samsung is covering the cost to repair this problem on some models. You can call 1-800-samsung to find out if your unit is covered.
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
TV made a buzzing noise then turned off. Now power light flashes
You have a very Technical problem with this TV. you may have 2 big problems, ballast and dmd. but it could be something else. If you decide to repair it, honestly you will spend more than 300dlls on it, if you like to, go to fixyourdlp.com
1helpful
2answers
Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
