SOURCE: Picture Station Sony DPP-FP55
the printer needs a proper servicing and dust cleaning done.as there is a sensor in the printer which detects whether there is paper ,or no paper in the paper tray ,that sensor is moved from its orignal position so this problem is coming.but servicing and cleaning will help.
thanks
SOURCE: Cannot print from PC with Vista to Sony DPP-FP30
I downloaded the appropriate driver for Vista windows from a website which has hundreds of different drivers and it works a treat now.
SOURCE: my sony dpp-fp55 leave 2/3 of the paper white while printing
They are thinking the cartridges are dirty or the heads. I am thinking it is a setting for the printer or an actual glitch in the printing program. If you have successfully printed on this printer before, then very carefully go through the settings, looking for print margins settings specifically. This sounds simple but you might want to make sure your paper trays are adjusted correctly.
SOURCE: Sony DPP-FP30 do not work with wista
Sony says DPP-FP30 is compatible with Vista (both 32-bit and 64-bit) and that the printer driver is included in the Microsoft Windows Vista operating system.
However red-eye reduction, Exit Print, Auto Fine Print, enlarging preview, and reducing preview are not supported.
Check this link:
http://esupport.sony.com/US/perl/news-item.pl?&news_id=129&mdl=DPPFP30#soft1
SOURCE: Sony Printer DPP-fp90
You may use your memory stick option to print. I means you shall copy your pictures to a memory stick card. Insert in into the printer. And print directly without your MAC. I use Sony DPP-FP70. It works.
