20 Most Recent Sony DPP-FP30 Thermal Photo Printer Questions & Answers
So there's good news and bad news. . The bad news is that it doesn't look like there is a driver for Mac, and Sony apparently has no intention of every developing/releasing one. . The good news is that you can still print photos by taking advantage of the printer's ability to print directly from a camera. . You can upload the photos directly to a memory card using a memory card reader, and then put the card into a camera and print from there. Note that the camera might not accept the photos if you are taking them out of iPhoto, because iPhoto does a conversion on imported pictures that the cameras sometimes don't understand when you try to put them back on the camera. If you want to edit the photos, use a program called GIMP instead of iPhoto. Here's the download link: http://gimp.lisanet.de/Website/Download.html . Hope this helps!
Sony DPP-FP30... | Answered on Sep 18, 2011
Hi there.
Unfortunately this is not MAC compatible. The only way to get this working with a MAC is using a VIRTUAL PC in your Mac. Once you are on the pc side of the machine, you can download the driver for the WINDOWS OS you will be using.
Let me know if you have further questions.
Thank you!
Sony DPP-FP30... | Answered on Sep 12, 2011
Install the drivers in XP or Vista compatibility mode.
Insert the setup disk in your CD/DVD drive. Choose to view the files in Explorer.
Scroll down to the file "Setup," which is identified as an application.
Right-click the file and select "Properties." Click the "Compatibility" tab at the top of the resulting window.
Check off "Run this program in compatibility mode for:" and choose "Windows Vista" or "Windows XP Service Pack 3" from the pop-up menu.
ALSO check "Run this program as administrator" at the bottom of the window.
Press "Apply," then "OK."
Now you can double-click the "Setup" file and run the software installer.
Sony DPP-FP30... | Answered on Mar 12, 2011
Sony printers are masterpeices when it comes to digital printing as they produce wonderful quality images.
If you got a new printer and it does the same thing this indicates that the problem iis emanating from the software with which you use in editing the pictures before sending the print command. Somewhere along the line some adjustment must have been made to the software relating to the alignment of the picture on the printer. Once this adjustment is corrected your printer will print fine.
Printers are devices which prints what command was sent to them and do not have any intelligence to act or edit documents on their own accord.
Hope this solution has been helpful?
Happy new year
Sony DPP-FP30... | Answered on Jan 04, 2011
The print head on the printer is bad, you will need to contact the dealer to inform them to know how many print the printer can produce before it park off. once this known, it will help know if to replace the print head.
Take care.
Sony DPP-FP30... | Answered on Oct 16, 2010
well the problem is that, Mac is not supported by Sony at least not on that model, I'll give you where you can check the supported operating systems if it doesn't help at least you can see what OS will work. Click here
Sony DPP-FP30... | Answered on May 26, 2010
Sony says DPP-FP30 is compatible with Vista (both 32-bit and 64-bit) and that the printer driver is included in the Microsoft Windows Vista operating system.
However red-eye reduction, Exit Print, Auto Fine Print, enlarging preview, and reducing preview are not supported.
Check this link:
http://esupport.sony.com/US/perl/news-item.pl?&news_id=129&mdl=DPPFP30#soft1
Sony DPP-FP30... | Answered on Aug 22, 2009
Sony DPP-FP30 Thermal Photo Printer Logo
28 questions posted
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
DPP Sony
  • DPP Sony
Most Popular Question
get windows 7
  • Office Equipment & Supplies
