I bought a new battery it charged a few minutes and then stopped.
Either the electronics in the charger or the battery have failed. Or there is something wrong with your power jack.
www.aurabuy.com/cheap-4800mah-6-cell-battery-for-gateway-m255-e-m255-m360s-m360sb-m360se-m360x-m360a-m360b-m360c-m460a-m460b-m460e-m460e-m460s-8550gb-paypal.html
SOURCE: Battery charging for few seconds before it stops
Either the electronics in the charger or the battery have failed. If you still have any warranty left on the laptop call Dell support and they will assist you in identifying which one has failed.
SOURCE: battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Testimonial: "good advice"
SOURCE: My battery on my ASUS
Check the voltage at the pins of the adapter. If present accordingg to the specifications then connect to the laptop and remove the battery from behind. Now check the voltage at the battery terminal of the laptop. if there is low or no voltage to the desired level then there are problems within the main board as this insufficient voltage will not charge the battery makeing it go down below level.
SOURCE: Netbook charging indicator light won't light
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead.
2. the battery bay is loose
3. the battery itself is loose
Hope this helps...
