Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Posted on Mar 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi WD-52525 shutting off periodically
I have a mitusbishi 52525 DLP tv that I can watch for about a half hour and then it shuts off. The orange light blinks for a while and then the green light blinks for a while longer and then goes out. I can turn the tv back on and at the bottom of the screen it asks if I've changed the bulb. I push cancle and I can watch it for only a few minutes and it goes out again. I've tried unplugging it, resetting it, and nothing seems to fix it.
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Mar 18, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
22250
Points
158
Replace the lamp/bulb
Mitsubibishi wd series 73"..Mitsubishi ws series 73" dlp. Works fine but after several hours of viewing screen scrambles then goes blue and sound goes off. I can switch to another input and watch ama
A couple of suggestions, if only on cable and using a box disconnect the set and box from power and after several minutes repower and see if a reboot helps.
The two models listed here both should also have a soft reset done with the original remote and the set on---Menu,1,2,3, enter.
1helpful
Hi, I have a Mitsubishi wd-57733 dlp tv that shuts down
Ballast is possible if repeated lamp failure but I have a solution I posted several times for this type of problem that works and is simple to try:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
3helpful
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
TV Shuts down
convergence amp IC's i would start with.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
