20 Most Recent Mitsubishi WD-57733 57" HDTV Questions & Answers
When was the last time you replaced the lamp? That sort of sounds like the ballast is unhappy with a bad lamp. The 57733 is a good TV. The other possibility is a stuck/dirty color wheel.
Check the lamp and see if it looks worn out(dark or grey in the tube down the center). Also make sure its either a Philips brand or Osram brand.
Let me know and Ill see what I can recommend next
Mitsubishi... | Answered on Sep 21, 2016
Sorry tv not repairable,the picture screen panel is broken or damages.The tv picture screen panel are 90% important to the tv and it is limited in production by the tv corporations,no where u can buy tv picture screen panel except the tvs corporations themselves.By replacing the tv picture panel,will cost the same as a new tv,by replacing the picture screen panel alone,because of it limited production and important to the tv itself.Sorry this not worth as a whole tv anymore,now tv only as salvages tv for it electronic boards for parts only now.
Mitsubishi... | Answered on Jan 25, 2015
Check fuse in plug , plug into a different socket - check mcb at fusebox - if not then main psu board blown most likely.
Mitsubishi... | Answered on Oct 16, 2014
not sure if you've figured this out yet or not, but the white spots are casused by a chip in the lamp, that chip would need to be replaced.
Mitsubishi... | Answered on Oct 13, 2014
it shoubld be on the back of your set.
Yes. It is most likely a lamp replacement issue.
Mitsubishi... | Answered on Aug 23, 2014
Hi Jim,
Green blinking light of death on Mitsubishi DLP TV means that the DM failed to booted up. I would advice you to replaced the 7 1000uf electrolytic capacitor on the DM board. Most of the time it fixed the symptoms. Please inquire at tvrepairworld.com if they have an available DM repair kit for V36 chassis (WD-57733 chassis).
Jdvillanueva
Mitsubishi... | Answered on Apr 04, 2014
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Mitsubishi... | Answered on Dec 24, 2013
Mitsubishi WD-57733 57" HDTV Logo
138 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
wd 57733 will attempt power up almost
  • Televison & Video
