LG 37LC7D 37 in. LCD HDTV Logo
A
Anonymous Posted on Mar 24, 2013
37 inches lg problem green light on but no picture
  • Anonymous Apr 03, 2016
    I have this problem, Power supply ok and internal fuse ok. Green remote light on, but no picture.
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Apr 03, 2016
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008547
Points
237762
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
5 Related Answers
David Low
  • 458 Answers
  • Posted on Mar 24, 2009
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Anonymous
  • Posted on Apr 06, 2009
SOURCE: LG RZ 37LZ55 37 in HDTV LCD Screen Dead
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
petraman7
Scott Frye
  • 1175 Answers
  • Posted on Apr 19, 2010
SOURCE: My LG 37 inch 37 had a popping noise at the back
Hi
Power supply failure. Check the LG site for a good tech
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jul 10, 2010
SOURCE: LG 37LC7D 37-inch 720p LCD HDTV
Unplug it for about an hour to let it reset itself and try again, if it still has problem then you will have to open it up or take it to the repair shop. The power supply module will have to be looked at first to make sure all the voltages are present. Right now the 5vdc standby power supply is working and may be partially function processor.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Anonymous
  • Posted on Aug 07, 2010
SOURCE: LG HD 37 INCH TV GREEN LINE APPEARING ALONG THE BOTTOM
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
LG 37 INCH TV FAULTY
that can be a power supply issue possibly bad caps or also the main board. If you need free tech assistance the people at www.tvrepairworld.com can assist with diagnosing whats going on with the TV
LG 37LC2D will not turn on
mine just did this tonight as well.... no answers yet?
4helpful
2answers
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
2helpful
Green power light goes on but there is no picture or sound
the green light is on and there is no sound or picture. how much does it cost to get this fixed. 2006 37 lcd?
2helpful
2answers
37 INCH LCD HD NO PICTURE GREEN LIGHT ON, BUT NO SOUND
CHECK THE FUSE ON THE INVERTER BOARD, IFHIS DOESNT IT SOLVE IT REPLACED THE CAPACITORS, IF STILL SAME PROBLEM, THEN YOUR BACKLIGHTS ARE SHOT, HAVE THEM REPLACED
2helpful
3answers
LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
BROKEN TV
Polaroid has a 1 year manufacturers in-home warranty on 32+ inch TV's. Contact them and they should send someone to fix the TV for you.
http://www.polaroid.com/company_info/ww.jsp?PRODUCT%3C%3Eprd_id=845524441765894%3FFOLDER%3C%3Efolder_id%3D2534374302029019&bmUID=1202320078795&bmLocale=en_US
Since it is still under warranty make it Polaroids "problem"
hope that helps!
2helpful
2answers
Cr1spy
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
