I have a zte concord v768 and i tried the hard reset where i turn the phone off and hold the down volume and power button until the android with the arrow shows up but when i press the home button instead of unlocking it just goes black and goes back to the green android. How can i factory reset it??
Just try with the below steps to hardreset your phone:-
1.Switch off the handset, and press the power-key and volume-down key at the same time until get recovery mode;
2.Press home key get into next interface;
3.There will be four choices:reboot system now;apply update from sdcard;wipe data/factory reset;wipe cache partition;
4.Use "Vol+" and "Vol-" to move the cursor up and down;
5.Move cursor to "wipe data/factory reset," press "menu" key to select it.
6.Then use vol- key to move the cursor to " yes-delete all user data" , press menu key to select it.
7.Then choose reboot system now ,you phone will reboot itself.
I tried but when i hit the home key it shows onw line of yellow lettering and just reboots...
I have the same problem, have you found a solution yet?
same problem here
HE JUST SAID THAT HE TRIED THAT AND IT DIDN'T WORK!!!!!! CAN SOMEONE ON THIS SITE EVER READ THE QUESTION BEFORE ANSWERING!?!?!
I has same problem with ZTE V768 ,
follow thease steps
download adb driver , and fastboot driver
If u already have good.
take out the battery and after few sec put it back and VOL UP + HOLD + POWER ON ) u will see green andriod logo
connect phone
reun CMD and go to adb/tools/fastboot -w and press entre
when se u see sucessfull type fastboot reboot
SOURCE: customers child has patterned locked
In the emergency dial enter *983*987# and your phone will be unlocked and reseted to factory defaults.
you used a regular usb cored. i had the same problem you have to send ut in to get a new one its broken you need a dat cord hope i helped
SOURCE: Samsung GT S3850 Corby II hard reset
* Put phone Download mode ( VOL UP + HOLD + POWER ON )
Download these
Follow This Step.
1. Download Multiloader
http://www.4shared.com/file/SLagBW72/multiloader_v565_.html
2. Handphone Download mode - press (Call/Green +volume up + Power ).
3. Samsung USB Drive.
http://www.sendspace.com/file/rf6jwp
4. S3850XEKC5 Files
http://hotfile.com/dl/112605771/748f030/S3850XEKC5.rar.html
5. Picture for Reference.
http://i302.photobucket.com/albums/nn83/errolkristine/mult.jpg
If u finished, connect phone with the computer in download mode.
and put the necessary files as shown in ref: picture and then click download.
SOURCE: Lg EnV VX9900 CLR Button Resets phone.
When you hit the clr button it will go back to the screen you where prior. When your booting up, it will show the Vcast screen. Maybe check your backlight setting.
this actually worked thank you candise cooper
how to reset my samsung s4 handphone
My zte v768 manages to come on but it just comes on to the point that says stick together, how can i get it to come up
I think you have to follow the same process herehttp://deviceteck.com/blog/2017/05/25/fo...
