SOURCE: bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
SOURCE: Bosch Dishwasher Model SHU66C soap door will not open
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
SOURCE: My one month old Bosch dishwasher Model SHE6AF06UC
think this means that your water pressure is not high enough for rinsing to be completed 100%. do you have low water pressure.
SOURCE: Door of detergent holder on Bosch dishwasher won't shut. It just pops open. Is there an easy fix?
Proceed with this step:
Timer
check the timer, and the linkage see it is defective.
Bi-metal switch or wax motor
test the swithc or the motor for defective.
Detergent cup, itself
can be clogged, for to open.
sincerely. God bless you.
