The SM58 uses balanced output. If the starsinger uses a 1/4 inch jack, it is unbalanced input and probbly requires a high impedance rather than the low impedance SM58 mic. You can get an impedance transformer to fix that problem.
The SM58 is a very rugged and reliable microphone and there are not many things to go wrong with it.
Assuming that you have tried using a different cable / amplifier to issolat ethe problem to teh microphone itself the most likely things are.
A wire has come off inside - gently unscrew the top of the mic - lift it off carefully lift because the wires inside are quite short.
A broken capsule - this usually results from dropping the mic on hard surfaces. Replacement capsules can be bought quite cheaply.Just tak careful note of the wiring order before disconnecting the old one.
The SM58 is a dynamic mic. It's actually a very simple device. Thus, it doesn't "degrade". If an SM58 fails, it usually fails catastrophically. Now, the problem for is that you don't know if the failure is in the handle (which includes a transformer) or the cartridge).
You can order a replacement cartridge from Shure and solder it in place, but might be better for you to just send the mic to Shure. I believe they will just replace the mic with a new one for their service fee.
If these are wired SM58 mics, they will probably need to be sent to Shure for repairs. The cost to repair is less than purchasing a new one, and they will usually just send you a new mic.
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
