ATI RADEON X1650 Graphic Card Logo
A
Anonymous Posted on Mar 16, 2013
How to install video card and connect the power supply on an ati p\n7127024100g
4 Related Answers
antiochpc
Kevin Shafer
  • 1314 Answers
  • Posted on Dec 12, 2008
SOURCE: Problem installing PCIe graphics card
All you need is an adapter cable like this.
Thanks and please take a moment to rate as fixya.
Anonymous
  • 36 Answers
  • Posted on Feb 09, 2009
SOURCE: Video card in Dell Inspiron
hi steve, either the video ati 7500 is not compatible with your motherboard, which is very unlikely... its a big possibility that your video card is defective
Anonymous
  • 564 Answers
  • Posted on Feb 18, 2009
SOURCE: ATI Radeon HD 2400 Pro install - computer won't boot when added
Click here to for your computer product specification.
ATI Radeon HD 2400 Pro is a PCIe and your computer is compatable only for PCI
hope this helps,
Thanks, Prem
Anonymous
  • 37 Answers
  • Posted on Sep 07, 2010
SOURCE: Fitted ATI Radeon x300 -
yes the motherboard powers the card but you need to make sure your power supply is sufficient enough to run the video card
Trouble with install second video card HD 5450 to emachines t6532
Unclear of your statement. (More like run-on sentence)
Problem heading statement reads,
"trouble with install second video card HD5450 TO eMachines T6532"
Need clarification
The eMachines T6532 Desktop PC uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
(Click on photo for a better image)
Has one long white PCI Express x16 slot. (Expansion Slot)
Only uses one graphics card at a time, will Not use two.
[Graphics card / Video card. Same/same]
Therefore I surmise you are not referring to adding a Second graphics card, but are referring to;
A) This is the second time you have added a graphics card.
Or,
B) This is the second ATI Radeon HD5450 graphics card.
Had one before. Removed it, and are using a new one.
Or,
C) This is the second time you have added a graphics card.
It is not an ATI Radeon HD5450 like the old one is.
Know this;
1) You can ONLY use the OnBoard (Integrated) graphics,
OR the graphics card.
You CANNOT use both.
When using a graphics card the monitor is plugged into it.
You cannot plug into the onboard graphics of the motherboard, with it installed in the computer.
Said differently;
With the graphics card physically installed in the computer, you cannot just unplug the monitor from the graphics card; and plug it into the OnBoard graphics of the motherboard.
[Also; Computer on, you CANNOT unplug a monitor, and plug it back in.
This = NO ]
2) Driver: Small piece of software that allows the Operating System to communicate with a device.
The device is the graphics card.
The version of Windows operating system was not stated.
Did you install the software from the Installation Disk? (CD/DVD)
Has the drivers on it, and the user interface software.
User interface software for an ATI graphics card, is Catalyst Control Center.
(Just to note; I'm using a Powercolor Radeon HD5450 graphics card, right now.
I'm using dual monitors.
HP 2009M - 20 inch widescreen LCD monitor, and an RCA L26HD31 HDTV as the main monitor. (26 inch HDTV)
They work GREAT! ]
(It is an ATI Radeon HD5450 graphics card just like yours, IF yours has 1GB of graphics memory.
Doesn't matter what graphics card manufacturer, makes that HD5450, it is still an ATI (AMD) design.
Powercolor, VisionTek, Sapphire, Diamond Multimedia, Mickey Mouse, or Goofy. It is still an ATI graphics card )
The ATI Radeon HD5450 graphics card, has to have a MINIMUM power requirement of 350 Watts.
Does your power supply have 350 Watts or more?
If it is the original power supply, the answer is NO.
Back then power supply manufacturers were 'fudging' the true maximum rated wattage.
Why?
Sold more power supplies.
Power supply rated at 250 Watts?
Nope.
More like 60 to 70 percent of that.
Divide 250 by 10.
= 25.
Take that times 6. = 150 Watts (60 percent)
Times 7 = 175 Watts (70 percent)
Would like your opening statements clarified.
Post back in a Comment.
Regards,
joecoolvette
Running Windows 7 Home Premium, recently tried installing Radeon X1300 AGP video card, and computer won't display anything or boot with it installed. With card unplugged and using onboard video it still...
Hi - I believe you might be suffering from one of two (or even both) problems. The video card sucks lots of power and I believe has a separate power connector on the card that should be connected. The type of connector varies with manufacturers; from a four pin floppy disc type to a molex type connector or even something proprietary.
Secondly -- It's recommended that you have a 350 watt or higher power supply in your system.
Either issue could keep your machine from booting.
Good Luck, Mikeywaf
3helpful
How do i install my ati x1900 video card on my mac pro
That card needs extra power - more than it can get thru the PCI-E socket - so do exactly what it's said : connect an extra power cable from the power source to the card.
2answers
So I'm trying to install a ATI Radeon X1650 Pro AGP card, I've seen where other people have tried and got the same results as me, but my question is, I've got 2 gigs of ram on a ADM Athalon 2400 Is this...
Firstly you must make sure your motherboard actually has an AGP slot. The newer ones have PCI-Express instead and you can't plug it in and there are no converters.
Yes, the card will work with that CPU and RAM. Everything depends on the motherboard, but if it's AGP and can do AGP x8 then all's well.
Make sure if the card requires extra power that your power supply can power it (for example if the power supply has the correct connector for the graphics card, and if it has the necesarry power to power it). Since it's not a high end card it probably doesn't even have the power connector in which case it's low power and it should work on pretty much any power supply over 350W.
You ask if that's enough; enough for what? A particular game or software? It'll run ok on older games, but newer ones like Call of Duty 4 should work but on very low settings. I'm not sure if your cpu can take that game tough, but the graphcis card can and the ram is enough.
Ati 9600se problems
I suspect that you are using too small a power supply. The display card uses a lot of power, to achieve the display rates. Try a heavier duty power supply
Dell Optiplex GX280 Video Card Install Problem
You hit that one right on the dot.  ATI website showed the specs for that graphics card you installed as needing a 300 Watt power supply.  Good news though... I researched newegg.com and I believe I found your 300W power supply.  There are 4 different Optiplex gx280 designs with 4 completely different power supplies.  Since you bought the low-profile video card, I believe you have the slim computer case and this power supply should work for you...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817374002
Good Luck
Dfi wt70ec socket 423 board never used and visiontekx1300512mb agp
Either video adapter is not seated properly. Remove the video card & reseat.
Also, check to ensure the monitor cable is connected properly.
Top ATI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
