Optoma EP739 Multimedia Projector Logo
Anonymous Posted on Mar 17, 2013
I changed a bulb to a socket type screw without turning off the circuit breaker, not I get no power when I turn on work light
Anonymous
Level 3:
  • Master 1,010 Answers
  • Posted on Mar 17, 2013
Anonymous
Master
Level 3:
Answers
1010
Questions
Helped
247249
Points
3078
  • Anonymous Mar 17, 2013
    I did that, when changing the socket in the light bulb thing I heard a pop and lights in garage went out
    I meant, check the fuse in the projector.
1helpful
Stupidly caused oven to short out and blow breaker and after resetting breaker, nothing works at all.
Tracey recheck that the breaker is reset properly,you may have blown the digital display/control board. In which case a tech. will have to diagnose and repair.
Why does only one of the two sockets in my ceiling light work at once?
There is no circuit that would do that (for instance if the bulb were in series with a plug it would not work when the bulb *isn't* there and would work poorly when the bulb *is* there. If they were in parallel they would not affect each other etc). It must be a loose connection and also turning the light would make the socket fail too. You can turn the power off at the circuit breakers, and uninstall the light and sockets, and take it apart and check. By the way, depending on what country you're in, there may be fire safety laws about some types of lights like that, for instance they are not allowed to hang down by the wire.
Sep 01, 2014 • Dryers
4answers
BULB REPLACEMENT
I found the articles on Harbor Breeze helpful for solving remote control problems. You can also check out the video below as well. I found the articles on Harbor Breeze Accessories helpful for solving remote control problems. You can also check out the video below as well.
May 26, 2013 • Dryers
1helpful
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
When I flip the manual switch it clicks but the lights wont turn on.
Manual override should turn lights ON-OFF even if timer has gone bad.
It sounds like problem is electrical.
Suspect line-up:
Test that timer is getting electricity from breaker.
Burned out bulb. Change bulbs. Spray WD-40 on bulb threads before installing bulb.
Outdoor wiring can go bad easily, outdoor bulb sockets become dirty and stop functioning.
Loose wire between breaker and timer -or- between timer and lights.
Loose wire inside timer box. Tighten screws.
Loose wire on circuit breaker. Tighten screw on circuit breaker.
Tripped circuit breaker: click circuit breaker all the way one direction and then all the way back other direction.
Bad circuit breaker. Move wire from one breaker to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
I have a 3 year old Panasonic Whisperlite FV-08VQL4 ceiling fan for the bathroom, with two CFL bulbs (18W each). One of the two bulb locations is bad -- it won't turn on, regardless of replacing the bulb...
Sounds like a loose wire inside the unit. But, I would try this. With the power off, both switch and circuit breaker, try and bend the center contact for the light bulb out; pull it out away from the back of the socket. This may be the bad contact. The center contact on the bulb touches this in order to get power up into the bulb. Using a small screw driver, try and scrape the surface of this contact to clean it a bit. DO ALL OF THIS WITH THE POWER OFF!!!
Hope this helps.
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
9helpful
How to change fog lights bulbs on my 2005 honda
  1. Remove the fog light mounting screw.
  2. Disconnect the connector from the fog light.
  3. Turn the socket about 45° counterclockwise and remove it from the housing.
  4. Remove the bulb from the socket.
To Install:
  1. Install the bulb in the socket without touching the glass with bare hands.
  2. Turn the socket about 45° clockwise to install it.
  3. Connect the connector to the fog light.
  4. Install the fog light mounting screw.
1helpful
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
9helpful
3answers
New bulbs in chandelier don't work
A light bulb is not a terribly complicated thing. I think you're saying that the bulbs are OK, but they do not seem to function in some of the chandelier sockets. Is that correct?
Assuming the bulbs are not burned out, the only reason this would occur is if they are not making good electrical contact with the socket. The bulb makes contact in two places, on is the threaded base and the other is the metal contact on the base of the bulb. My guess would be they are not threading in quite right and then you're not able to screw them all the way in so the base makes electrical contact.
Before you rate this solution I hope you'll take into account that I'm not paid to do this, I'm just trying to help. I have no idea what you're reaction will be, but I'm really getting tired of getting poor ratings for trying to help...especially when I seem to be the only one who responds on a question.
Dec 29, 2007 • Dryers
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
