Microsoft SQL Server 2005 Enterprise Edition for PC Logo
Posted on Feb 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sql procedure i want to know about sql procedure in sql server
Vilar Kuzmar
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 11 Answers
  • Posted on Jul 06, 2021
Vilar Kuzmar
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Answers
11
Questions
0
Helped
1270
Points
46
Hey! So it kind of depends on your use case and why you think you need an alternative. In other words, why is SQLite not going to suffice? Without knowing why you want a database and why SQLite might not work for you, someone can't give too much in the way of useful advice to try dotconnect for sqlite www.devart.com/dotconnect/sqlite/
John Walker
Level 2:
Social Spider:
An expert who has shared 50 answers on their Facebook wall.
  • Microsoft Expert 47 Answers
  • Posted on Jul 04, 2016
John Walker
Microsoft Expert
Level 2:
Social Spider:
Answers
47
Questions
0
Helped
26139
Points
349
Take a look at this link, it will give you an overview of stored procedure in sql server:
Benefits of Using Stored Procedures In SQL Server
Anonymous
Level 3:
President:
  • Master 392 Answers
  • Posted on Feb 25, 2009
Anonymous
Master
Level 3:
President:
Answers
392
Questions
Helped
148766
Points
1180
Dear friend you can get all your answers about stored procedure in sql server through this link:
http://www.sql-server-performance.com/articles/dba/stored_procedures_basics_p1.aspx
good luck
1helpful
6answers
Repair a corrupt SQL database in SQL 2005
Known as the leading solution provider in the field of data recovery and data conversions, the company has created a niche for another efficient tool known as SQL Server Repair Toolbox. The MS SQL repair tool reads *.mdf and *.ndf files and saves data, structure, links, etc. as SQL scripts or exports directly to Microsoft SQL Server through direct connect. read more details SQL Server Repair Toolbox
tip
Reset sql sa password directly and efficiently
A few days ago, I had a painful experience that I lost SA password on my MS SQL Server database, and I almost took the whole weekend to look for an efficient way to reset SA password. I asked friends, searched on Internet and even bought some book.... Fortunately, I finally got a SQL server password recovery software and it instantly reset SA password without data loss. And I also got a couple of good solutions for sql sa password reset to save your weekend in case you have lost or forgot MS SQL Server passwords (SA password!).
Option 1 : Use MS SQL Server Password Unlocker to Recover/Reset SA Password
The most direct, efficient way to reset SA password is to take use of the third part utility - SQL server password recovery software. Just two steps:
Step 1: Access to master.mdf file, which is default at C:\Program Files\Microsoft SQL Server\MSSQL\Data\master.mdf
Step 2: Select SA password and reset SA password
So, Reset SA password successfully!
Option 2 : Recover or Reset SA Password with Other SQL Server Login
If there is any other SQL Server Login that is a member of sysadmin role, you can log in using that account and reset SA password of SQL Server. Reset sql sa password as described here :
SQL SERVER - Reset Password of SA Login Using Management Studio.
Login into SQL Server using Windows Authentication.
In Object Explorer, open Security folder, open Logins folder. Right Click on
SA account and go to Properties.
Reset SA password, and confirm it. Click OK.
Make sure to restart the SQL Server and all its services and test new password by log into system using SA login and new password.
Option 3 : Recover or Reset SA Password with Windows Login that is a member of Windows Admin Group
If there is any other Windows Login that is a member of Windows Admin Group, log in using that account. Start SQL Server in Single User Mode as described followings :
SQL SERVER - Start SQL Server Instance in Single User Mode.
There are certain situation when user wants to start SQL Server Engine in "single user" mode from the start up.
To start SQL Server in single user mode is very simple procedure as displayed below.
Go to SQL Server Configuration Manager and click on SQL Server 2005 Services. Click on desired SQL Server instance and right click go to properties. On the Advance table enter param '-m;' before existing params in Startup Parameters box.
Make sure that you entered semi-comma after -m. Once that is completed, restart SQL Server services to take this in effect. Once this is done, now you will be only able to connect SQL Server using sqlcmd.
on Oct 05, 2010 • Computers & Internet
tip
How to Create and Remove SQL Server Password
SQL Server is a Microsoft product used to manage and storeinformation. It uses tables to contain large sets of records for thedatabase. Do you have a SQL server and have you ever used SQL server?Do you know how to create a SQL Server passwordto protect your data stored on SQL server? What to do if you forgetyour SQL password? Following it will introduce you how to create a SQLpassword. And it also tells you how to remove SQL Server password ifyou forget as password can be easily lost.
How to create a SQL Server password?
As we know, it is an important security measure to set a passwordfor user accounts and in particular the SA account. And it is very easyfor you to create a SQL Server password. Just follow the simpleinstructions.
1. Open the Microsoft SQL Server Management Studio program from the Start menu bar in Windows.
2. Click on the SQL Server instance on which the new user will be created.
3. Right-click the Security folder, point to New, and then click Login.
4. On the General page, enter a name for the new login in the Login name box.
5. Select SQL Server Authentication and enter a password for the login.
6. Select the password policy options that should be applied to the new login. In general, enforcing password policy is the more secure option.
7. Click the OK to complete the creation of the new user.
Sometimes it happens that you ignore or forget the systemadministrator password. What will you do if you forget SQL password andcannot access to SQL database? The effective way I know is to remove SQL Server passwordwith the help of SQL Server password remover software. MS SQL ServerPassword Unlocker is one of the good MS SQL password remover toolswhich can help you remove SQL password in a few seconds.
How to remove SQL password with Windows Password Unlocker?
MS SQL Server Password Unlocker is handy SQL Server password remover software for you to reset SQLpassword including reset SA password and other user passwords. It caneasily remove SQL Server password for Microsoft SQL Server2000/2005/2008 in a minute. You don’t need to install MS SQL Server onyour PC, and the file in master.mdf format is enough for you to removeSQL Server password and set a new one for it.
Step 1. Download and install MS SQL Server Password Unlocker, and run the application.
Step 2. Click Open to import your master.mdf file. All the user names of your MS SQL Server will be displayed.
Step 3. Select an SQL account, click Change password button.
Step 4. Type a new password, and then click OK.
This SQL account password has been reset. You can login with the newly set SQL password. Although it is easy for you to remove SQL Server passwordwith SQL password remover, it is better to keep your SQL password inheart. Or you can also write it down on a paper and keep in a safeplace.
on Sep 07, 2010 • Computers & Internet
2helpful
15answers
How can I repair a corrupted MDF files and SQL server?
Similar question has been answered here: http://www.fixya.com/support/t24364927-sql_repair_recovery_process_very
Before asking any question in the forum, first you need to search your problem.
SQL Server 2000 SP3 - Installation Path
The only way to change it. Is to reinstall the SQL Server, and be guided accordingly once you meet the setup option you need to change the folder destination where you can setup the sql.
Hoping this will be the solution you are looking for.
Best Regards,
Philip
1helpful
SQL server won't work on my laptop
Two ways to access your server. First, make sure the SQL Server Service is running. Start | Run | Services.msc | Enter. Look for Microsoft SQL Server Service and that it's running. Or Look for the SQL Service Broker icon by the clock and see that it's running. The default instance of SQL Server uses the Hostname. Start | Run | Cmd | Enter. The type hostname. This will be the name to access to server. Then type IPCONFIG, this is then the IP address that you could also use to access it.
SQL Server runs on port 1433, so any firewall has to have it open.
Open Query Analyzer, type in the hostname or ip of the local box, type in "sa" and the password for sa (if setup in mixed mode) or Windows Authentication.
Once you login in, you should now see the databases in the Tree on the left side under the Server | Databases node.
Your description though states "SQL Server won't work on my laptop". TO answer this, the only two SQL Editions that work on anything other than "SERVER" software is SQL Professional and SQL Developer. All others have to be on a "SERVER" platform.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
