Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
