Not breaker, not fuse, the fan wont turn on over stove nothing. need to get working and fan heat from stove. please help. cant afford new one
SOURCE: microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit. The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
SOURCE: microwave oven not functioning
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: MCM1290A Microwave Oven: the timer counts down but it wont heat or the turn...
Probably a bad door switch. See this file.
SOURCE: will not heat up but it turns on and runs
the light won't come on how can i get the light bulb out?
SOURCE: Magic Chef MCO 153 UQ heats but doesnt' turn
You can still use it, but must be aware that this is a relatively high power microwave, so food will burn if it isn't turned.
