Have you tried pressing a channel button? Get a cheap programmable multi remote and programme that until the TV responds (You have this problem listed under TV's (CRT) but its not a CRT :))
most remotes have search feature where you systematically press the power button until something happensmost remotes have search feature where you systematically press the power button until something happens
You can't post conmments that contain an email address.
The relay should pull in steadily. Check the connections with a meter, on the motor. The battery may be fine but a little corrosion on a battery contact will cause this.
What dose it do after starting then you turn it off whet dose it do /how and wheat type of sound dose it make ,,dose it just go clonk and nothing else/or dose it turn over slowly and dont fire Iwant to get all information before stating the problem.
If it tested ok then the starter should be good
