My camera wont take pictures. there is a green line across the lens and is pitch black
Hi Jennifer,
Not too sure what that is, but first thing I would check is that you lens is set to its smallest aperture, such as f/22. Many times that err message means the lens is not closed down all the way. After closing the lens down the camera dials will set the aperture. Also, on many Nikon D type lens, not the G type, there is a small push pull button to lock the lens as it smallest opening.
Cordially,
SOURCE: camera flashes "error" when turned on
Check if the aperture is set on anything other than 22. This would generate an error message. the N50 (and other auto Nikon cameras) needs to have the lens aperture set to the smallest -- AutoFocus lenses have a lock on them to lock the aperture at the smallest. Some models, such as the N5, can be set to use either the lens' aperture ring or the camera's command dial to set the aperture, but most simpler Nikon auto cameras can only be set by the camera. Setting the lens to its smallest aperture tells the camera that it can control the lens. If the lens is set to anything else than the smallest aperture, F-- shows up on the camera's LCD, and the camera locks up. Check your camera manual for complete info.
SOURCE: ERR message
unmount and remount the lens. Make sure you have the aperture ring on the lens set at the minimum f-stop number, ie f22, f32. There should be a small tab on the lens to lock the aperture ring in that position
SOURCE: nikon n55 film camera
You must have your lens set to the minimum aperture setting for this camera to function. I.E. f22,f32. The aperture ring moves a small tab on the outside of the mount ring when in that position.
SOURCE: MY N50 CAMERA IS FLASHING ERR
yes in order to fix this camera you need to replace the film transpot unit assembly and re-adjuster youre camera to factory ****. MIKE REPAIR TEC.
SOURCE: (E) flashing err
The lens aperture ring will need to be set to the largest number, and locked to that point. This allows the camera to control the aperture as it needs. If you have changed lenses to something other than what came with the camera this could also be the problem. Again make sure the aperture is set on the largest number and the problem should go away.
