It could be either the control board or a bad actuator if it goes through sensing, fills and washes and drains but just does not spin then odds are the actuator is not shifting it from wash to spin or the main board is sending the signal to the actuator to tell it to shift.
My top load Whirlpool washer won spin how do fix it
IT WAS THE CONTROL ELECTRIC OR COMPUTER BOARD WAS DEFECTED. I CHANGED A NEW COMPUTER BOARD NOW IT IS WORKING WELL
SOURCE: Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
SOURCE: Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
