Hayward SAND FILTER, PRO SERIES Logo
A
Anonymous Posted on Mar 04, 2013
HOW TO START MY HAYWARD PRO SERIES SP0714T1 - Hayward SAND FILTER, PRO SERIES
Robco Water
Level 2:
Champion:
  • Hayward Expert 258 Answers
  • Posted on Jul 26, 2019
Robco Water
Hayward Expert
Level 2:
Champion:
Answers
258
Questions
0
Helped
152547
Points
337
I always start a new filter in backwash mode. that way, any dust will be washed away and not into the swimming pool
2 Related Answers
Anonymous
  • 640 Answers
  • Posted on May 24, 2010
SOURCE: no suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
john224
John Prohaska
  • 1378 Answers
  • Posted on Apr 29, 2011
SOURCE: is the Hayward s210 pro series 21" top mount above
Thank you for posting your question here on Fixya.com.
32' round by how deep? Flow rate is how you size a filter so with total gallons you can calculate how many per minute will add up to the whole pool being turned over is 6-8 hours. The pump and filter are then sized for that required flow...Assuming the pool is an above ground ~4' average depth then total gallons would be about 24,000 gallons. For an 8 hour turnover you would need about 50 gallons per minute. The 210T, T for top mount, is designed to handle up to 44 gallons per minute and turn over a 21,000 gallon pool in 8 hours or a 26,000 gallon pool in 10.
What that basically means is that using a 210 on a pool 32 x 4 would be pushing it. It will work but you will end up backwashing more frequently which raises the overall cost of running the pool. If it is not to late a 24" filter would be better; especially if you have periods of time in your pool season where heavy amounts of debris such as pollen get into the water. A 21" filter won't handle any over a normal filtration load.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
1helpful
I cannot read the diagram on top of my hayward sand tank filter pro-series s244t filter,close,waste which way
go to westport pools.com and see if you can find a picture of it or go to hayward filters..
1helpful
I need an owners manual
Here is a copy of the manual for these pool filters. The first link is for the Pro Series S models. The second if for the pro series T models.
http://www.backyardcitypools.com/images/hayward/side-mount-filter-manual.pdf
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
Filter problem with hayward pool system
You didn't say what your exact problem was so troubleshooting with you might be difficult. Below is a link to the owners manual for these pool filters. You should be able to get your filter running properly using this.
1helpful
I have water leaking from under my hayward pool filter...any suggestions?
Try consulting the the owners manual for these pool filters. They have a pretty good trouble shooting guide and it should be able to help you correct your problem.
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
john h
ZJ Limited
ZJ Limited
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
