Not using the heater and using half strength Bissell 2X cleaning formula.
You must be very careful when using a vacuum on a rug. You can accidentally do irreversible damage. For more information check us out at Carpet Cleaning Star
Hey Jeff! Some Oriental rugs should not be cleaned with water. You may want to contact the manufacturer of the Oriental rugs regarding their care instructions.
SOURCE: lost manual for bissell pro2X rug cleaner can I get inst. on line?
Get one from Bissell or download one on-line.
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
SOURCE: bissell pro heater 2x won't spray
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
SOURCE: my bissell proheat rug shampooer wont wet carpet at all
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
gfhjdhg
SOURCE: Bissell Proheat 2x TurboDoes not pick up the water after cleaning
heatman101
m,nb
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
