There is a rewind clutch pin at the bottom base plate. The pin must be pushed in, in order to rewind exposed film. When I push the pin in, it does not remain pushed in, but reverts back to its original position. I must hold the pin in with my right thumb and rewind the film with my left hand. Thank you. Tony
SOURCE: Pentax ME SuperProgram shutter button doesn't release shutter
It is possible that the mirror is stuck in th "up" position. You should be able to fire the shutter as you say on the 125x setting with no batteries. You can download the manual from the link below: http://mcfaddenphoto.com/camera_manuals/pdf/ME_Super.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: location of rewind pin for nikon n6006 film camera
There is a safety switch to prevent accidental operation. Hold the camera like you are taking a photo. Rotate the camera down so the lense is pointing towards the floor and you are now looking at the bottom of the camera. On the right is a small button. In the middle is a slide switch with an arrow pointing to the left. You need to hold in the button on the right while sliding the switch to the left.
SOURCE: clutch position sensor on dodge 2500
Jim, I have the same problem. Looking in my Chilton's manual doesn't help much. But, if you look at the firewall from the driver's seat, where the clutch master cylinder rod goes through the firewall, you will see a plastic cylinder around the rod. There should be a wire that goes from that plastic cylinder and connects into a wiring harness. The manual says that if you separate the clutch position sensor wire from the wiring harness, and jumper the two contacts at that connection in the wiring harness, you will bypass the clutch position sensor switch. I have not yet done this but it is the recommended method of debugging starting problems. If you continue to have problems, I can email to you the section of the Chilton's manual for evaluating the starting system. At least I think I can get my computer to copy this section of the manual. The manual does not give the location of the clutch position sensor but that is the only location i can find that meets the description. I have a 1999 Ram 3500 4WD diesel quad cab.
David Wagner [email protected]
SOURCE: I have a 90' Isuzu pickup 4x4. The clutch pedal
you have either air in the line or a bad slave cylinder
SOURCE: Clutch push rod will not depress to engage
go to this http://www.cmsnl.com/yamaha-rt1-19701971_model8356/partslist/A-09.html and then click on "view big image", this will give you a diagram of the clutch etc,, the adjustment (No. 26) may need looking at, or (No.11,12,) have broken.Basically you turn 26 in (clockwise) untill you feel light resistance then back off 1/2 turn (been years since i worked on one of these!) this should give you freeplay, have you just got the bike?, and do you think it has been stripped lately(ie the clutch). PS I am not affiliated with the web site i offered above, just a handy reference for you maybe? cheers
