20 Most Recent Pentax Optio S50 Digital Camera Questions & Answers
35answers
Sony cybershot DSC-S50(not focusing)
After reading other solutions on this same error message, I decided to follow the advice of one that did not require taking it to the shop and having it repaired. I hit the barrell against the table with two good whacks, and it the error message disappeared. The zoom now works and so does my auto focus and manual focus. Problem solved, believe it or not. I held my breath because I was scared I would break it, but now it's fixed.
12/26/2015 1:40:04 PM • Pentax Optio S50... • Answered on Dec 26, 2015
How to reset sony dsc-s50
See page 14 of the manual, which can be downloaded here... http://www.manualslib.com/manual/361026/Pentax-Optio-S50.html
7/14/2014 2:29:06 AM • Pentax Optio S50... • Answered on Jul 14, 2014
3answers
I lost my pictures on my sd card- can I get them
yes, you can get back deleted pictures from sd card with card recovery software like asoftech photo recovery.1. Do not save any new file to memory card.2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)http://www.asoftech.com/apr/4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
6/6/2014 10:28:28 AM • Pentax Optio S50... • Answered on Jun 06, 2014
0answers
0answers
manual
manual
Transferring Photos from Built In Memory to Memory Card
Use the "Copy image/sound" command in the playback menu.
8/24/2012 6:35:32 PM • Pentax Optio S50... • Answered on Aug 24, 2012
Chager
There is no charger for the S50. It uses standard AA batteries. If you want to use rechargeable batteries then you must charge them using a separate charger. AA chargers should be available at just about any department, electronics, or office-supply store.
8/24/2012 6:35:28 PM • Pentax Optio S50... • Answered on Aug 24, 2012
Transferring pictures from camera to computer
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
8/24/2012 6:34:41 PM • Pentax Optio S50... • Answered on Aug 24, 2012
Where can i download a driver for optio s50 please
You don't need a driver.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
8/24/2012 6:29:10 PM • Pentax Optio S50... • Answered on Aug 24, 2012
How do I cure memory card error even though the card isnt locked?
The S50 works with SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
5/16/2012 4:38:47 PM • Pentax Optio S50... • Answered on May 16, 2012
2answers
Battery depleted
Hi there - I just experienced this problem with a Pentax Optio S30 (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
1/3/2012 5:28:57 PM • Pentax Optio S50... • Answered on Jan 03, 2012
Error massage 61:00 on sony
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
9/8/2011 6:51:16 PM • Pentax Optio S50... • Answered on Sep 08, 2011
I really like my camera
You can download the manual from the manufacturer's web site at
http://www.pentaximaging.com/files/manual/OptioS50_Web.pdf
7/27/2011 9:21:02 PM • Pentax Optio S50... • Answered on Jul 27, 2011
2answers
0x0211 lens cover error
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
9/19/2010 10:15:55 PM • Pentax Optio S50... • Answered on Sep 19, 2010
Pentax Optio S50 Digital Camera Logo
91 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
lost pictures sd card get
  • Cameras
