Panasonic KX-T7735 Corded Phone Logo
Posted on Mar 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to disable an alarm that goes off everyday.
Need to disable an alarm that goes off every morning on the 101 and 102 extensions. The phone system was inherited and the system password is unknown.
Carl Navarro
Level 3:
  • Panasonic Master 2,460 Answers
  • Posted on Mar 14, 2013
Carl Navarro
Panasonic Master
Level 3:
Answers
2460
Questions
Helped
1155934
Points
7314
No password needed. From the phones, dial 790 on the intercom.
The TV turns on everyday at 6 am by itself. How do I turn that off?
look at your users guide , the instruction s are in it or you can go to setting when you get to alarm click on icon then turn alarm off . hope this helps .
Alarm goes off at 5:00 am everyday
You need to check the manual for the alarm settings menu that allows you to go through the settings and disable the alarm.
2answers
Antitheft system keep goes on so i can't start my vehicle
It is telling me to lock the doors with the key, this will arm the system, then you should be able to unlock the doors after about 3 seconds and this should disarm the system. Also, if it doesn''t try unlocking the passenger side door or the back glass with the key. Let me know you must wait at least 3 seconds before unlocking back glass or passenger door to disarm system once one door is unlocked without setting off alarm it is disabled. hope this helps
1helpful
2answers
How to disable alarm on 95 jaguar xj6
Your Car is equipped with an Electronic Security System. If you disable it (which most probably you can not), you will bet on security of your car. If you still want to disable it, you should contact your Dealer or Authorized Service Station with Purchase Bill. If possible, they'll change locking system to old one.
Dictioary i need to turn off
You can go to message settings or the options in message and look for dictionary or T9 and turn T9 off.
If you want the alarm to ring each morning you can go to clock or alarm and set a particular time and set the repetition to everyday or weekly as you desire. You can also cancel the alarm simply by deleting or removing the alarm time that you have set which will be given in the options
Turn off alarm system
SEE information posted to
http://www.fixya.com/cars/t4154105-1998_jeep_grand_cherokee_alarm_will_set
mine did the same, so i had to stop using it
i did read somewhere that there is a way to ground a particular wire to disable (trying to locate that article for you ... i have not tried that yet).
11helpful
2answers
The alarm clock on S5230 soemtimes work and sometimes it doesnot work, please help
Here's how you do it:
Menu--Alarms--Tap to create--Alarm Name and Alarm Time [the time you want the alarm to go off] (I'm sure you can fill that up)--Now here is the part where you are facing the issue--The Alarm Repeat--Now press the Week days Tab--Select Everyday if you want the alarm to repeat everyday or select alternate days--Click Save.
Now the alarm will go off according to your set schedule.
If you need more help on that do let me know.
Calendar/clock keeps changing to wrong date (Nokia 6220 classic)
ok mate its probly ur settings ave ya got it on manuel and if ya do dat wud probly be the problem switch it to auto update and time and that shud do it for ya tell us if it works for ya
Alarm Goes off
This is a known bug in the P990 firmware (I personally went crazy from this). You need to update to the latest firmware for this issue to be fixed.
SET UP NEW VOICE MAIL
You will have to get into system admin and reset the password on that extensions mailbox.
Contact your system administrator.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
