New World E70DOa Electric Double Oven Logo
Posted on Feb 19, 2009
Can not set clock
Unable to set the clock (keeps flashing) so the oven does not work.
Do not have a manual
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Nov 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5263
Points
16
For the NW09DO, press the outer two buttons ("-" and "+") together and hold for three or four seconds. Then press "+" to advance the clock/time and "-" to go back.
When the correct time is showing, leave the buttons alone for four or five seconds.
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Feb 19, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
19246
Points
85
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
3 Related Answers
Anonymous
  • 6784 Answers
  • Posted on May 29, 2009
SOURCE: oven will not stay on
HI. this is a control fault that can be confirmed by unplugging the unit for 5 minutes. if the control continues to cycle from auto to manual, replace the control board(EOC/Clock)
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jul 19, 2009
SOURCE: Cannot set time and Oven will not operate
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
Anonymous
  • 12 Answers
  • Posted on Mar 30, 2010
SOURCE: The clock on my Cambridge oven wont work, I cannot
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Technika Freestanding Oven TU950TLE8
Nice Australian cooker but an unknown make to us here in North America.
Clocks always flash when you cut the power to inform you that the clock is incorrect. Perhaps you had a power cut in the night. If you have tried to set the time and can't, you may have a sticky button.
https://www.manualslib.com/manual/1108521/Technika-Tu950tme8.html?page=16#manual
Apr 19, 2022 • Ovens
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
2answers
After a power outage, the oven control light keeps flashing.
You have too reset clock pressing two buttons works for me
Nov 09, 2015 • Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 • Ovens
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
Mar 30, 2010 • Ovens
1helpful
Oven will not stay on
May 28, 2009 • Ovens
Unable to set clock upon installation. Unit has a button
Hold in the button for a few seconds and the numbers will flash. Then use the up or down arrow. Should do it for u. good luck
3answers
Main Oven Issue??
the clock need to be set to work the main oven
Top New World Ovens Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a New World Oven Expert? Answer questions, earn points and help others
