1998 Nissan Altima Logo
Posted on Feb 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Automatic won`t change above second gear
It`s a 98 nissan almera auto, it won`t change gear, it goes from 1st to 2nd but won`t change to 3rd
  • Anonymous Mar 10, 2009
    i have the same problem. something to do with gearbox. probably have to change entire gearbox. no guarantee will work. quite expensive.
  • Anonymous Mar 24, 2014
    Automatic
mike raines
Level 2:
  • Expert 120 Answers
  • Posted on Feb 19, 2009
mike raines
Expert
Level 2:
Answers
120
Questions
0
Helped
78914
Points
373
Tranny shop time tranny pump problem
1 Related Answer
Anonymous
  • 10 Answers
SOURCE: Automatic won`t change above second gear
sounds like the selector box at fault but change the auto oil and filter with some treatment and this should solve youre problem
2005 nissan x-trail auto will not go into 2nd gear. It goes from 1st to 3rd. does it in 2 wheel drive 4 wheel drive plus in full lock. Also it will not go into over drive.
automatic or manual ?
if not a linkage or adjustment needed
auto
=probably a shift solenoid problem
get to the solenoids with the pan off
manual =syncro
My 1995 nissan altima transmission is not changing from 2nd to 3rd gear
check the linkages from gear stick to gearbox may be loose.
1helpful
Hyundia starex auto will not change from 3rd gear
may hav burn a shift solenoid--put car on a scanner--local parts place does it for free--nomerical codes will show and explained in a manual--but bfore replacin a part a more detailed scan shud b performed
Delay in Auto shifting from 2nd to 3rd gear
Check your ignition coils. One of mine was bad and when I replaced it, the shifting issue stopped.
1helpful
1998 Dodge Grand Caravan will not shif into 2nd
Most likely the second gear section of the transmission has gone bad. There are 3 or 4 different gear sections or assemblies in an automatic transmission, when they go bad, they go bad.
2helpful
Transmission problem in E230 Benz
What you need to check is the transmission release bearing because if there is a clearance on the release bearing you will encounter this problem and also check the transmission oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
1996 Nissan Maxima no 2nd gear on auto transmission?
do not flush the trans, that will make it worse.
My friend you have no second gear, you need trans rebuilt.
If you flush it now you can cause more damage.
3helpful
2helpful
2answers
98 Civic Auto Trans Slippage
you need to replace clutch pack for that gear can be ordered seperately from parts store or dealer if you want to save money call peach street auto recycling at 1800-365-2341 for a warrantied used one! also might be time for change trans filter and fluid filter could be slightly clogged but I lean towards clutch pack I replace these alot on Hondas
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
