I am looking to hook my yamaha HTR-5830 wirelessly
SOURCE: yamaha htr-5830
I own this receiver, and 18db is damn loud. Granted - your room might be significantly larger than mine with your speakers spread much further apart, or your speakers might be much less efficient than mine (this means that they want more power than the receiver can dish out - I have whatever speakers came with the "YAMAHA Home Theater in a Box" [the model that came with the HTR-5830]), but I'm pretty sure that the receiver doesn't get any louder (or at least not much). My suggestion is to turn down the volume to about -20db and work up from there after the movie has started. It might be easier to test the volume using music. The negative sign is deceiving - I rarely bring mine up to 0db. Also check the resistance - there's a red switch on the back of the receiver that switches between 6 and 8 ohms - make sure that it matches your speakers' resistance. If turning down the volume doesn't work, then post the problem again. Hope This Helps.
SOURCE: Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
SOURCE: 4 ohm speakers on Yamaha HTR 5540
Model number of the Lux? The only unknown to me regarding the answer is if the Lux speakers are designed for non-Lux attachment. If there are molded connectors on their leads I would be cautious as that is usually the manufacturer's subltlke clue that you really don't want toi mix them with other makers. If they're bare wire I think you're ok.
The impedance selector on the receiver supports minimum 4-ohm front and 6-ohm center and rear, so you'd be marginal on those last two, but barring excessive high volumes I'd think it would work. The powered sub is supported and its impedance spec is irrelevant.
Just curious, is this an upgrade in electronics? From what?
Testimonial: "Thanks for the helpful advice. I'll watch out the high volumes for rear speakers. the model number for Lux Audio is LUX-8500. yea the leads are bare."
SOURCE: Yamaha HTR-5830 does not work with Sony PS3
Make sure you have the "audio input mode" on "Auto" it's a small button on the front of the Yamaha. Then go into the PS3's Audio setup and make sure it's set to Digital. Hope this helps
