24 band equalizer
SOURCE: installing pyramid 795cd equalizer
cd player or dvd player output------------to equalizer input---------equalizer output---------amplifier input--------amplifier output ----------to speakers
SOURCE: I've tried to hook up
Dual XR4110 is an integrated radio/USB unit - it has in it an amplifier.
Pyramid 801 is an equalizer with a powerful stereo amplifier in it . If you want to connect it to the Dual you will need to use the preamp outputs on the Dual to its inputs and then connect all the speakers to it (you will no longer use the power connector from the Dual for the speakers). For a proper wiring the speakers will have to be put in series, not in parallel (one pair per side) - if you put it in parallel the resulting impedance will be 2 ohms and the amplifier in the Pyramid will be damaged; this is what is happening now. Make sure to respect the polarity of the speakers or it will sound badly.
SOURCE: I need a wiring diagram
Click on MANUAL DOWNLOAD
LOOK PAGE 4 INTO THE PDF FILE!!!!
http://www.pyramidcaraudio.com/sku/903G/10-Band-Half-Din-Power-Booster-Graphic-Equalizer-Amplifier-200-Watts#
