20 Most Recent Pyramid XPA-100 Amplifier Questions & Answers
Fan is to loud
It might need the fan plugged in to make a full curcit and that's why it won't turn on
3/29/2013 10:07:58 AM • Pyramid XPA-100... • Answered on Mar 29, 2013
How to fix a flashing light on cyrus power amp
What exact model? Do you mean the "protection" indicator?
You might find some help or documentation here...
http://www.cyrusaudio.com/product-archive/power-amplifiers
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure
the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without
addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
1/15/2011 4:53:51 PM • Pyramid XPA-100... • Answered on Jan 15, 2011
I have a pyramind sea 4600 eq and want to hook it
USE THE TAPE IN AND OUT DONT FORGET TO TURN ON THE TAPE MON IN FRONT
6/22/2017 3:56:12 PM • Pyramid Audio... • Answered on Jun 22, 2017
0answers
My pyramid 1000 watt amp only plays when turned all the way up???
Set your gain control on it
11/3/2012 6:24:50 AM • Pyramid Audio... • Answered on Nov 03, 2012
Can I replace the bulb
Hi, yes sure you can. Just be sure when disassembling to make notes where necessary to keep track of where parts go-and when you get to the lamps ( either under or in back of the meters-use a volt/ohm meter to measure to voltage so you know the size to replace them with ie.. a 6 volt or 12volt. be careful when powering on a disassembled unit ( no parts touching each other, touching a metal part of cabinet) and if you want you can wrap some electricians tape around loose or exposed parts for safety. Good luck, I hope this was of some help and thanks for choosing FixYa. Prodzilla
4/20/2011 7:17:43 AM • Pyramid Audio... • Answered on Apr 20, 2011
How to hook up a pyramid pro plus 4 channel
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
7/27/2009 2:52:13 AM • Pyramid Audio... • Answered on Jul 27, 2009
HI i have two problems with the new amp we are
is the positive cable hooked to the battery or the fuse box and it sounds like a grounding problem
6/30/2009 7:33:49 PM • Pyramid Audio... • Answered on Jun 30, 2009
Vocalizer 3 output checked cables and swapped out. 1300 watt power adaptor lights up. sound indicator light is on but no sound. tried mono and stereo. power adaptor problem?
If the display is working, you have audio. Check your amplifier. 1300Watt adaptor ... This unit draws a very low power and that is not needed.
4/24/2024 7:18:55 AM • Audio Players &... • Answered 21 hours ago
How do I change to degree mode on my porpo YH-2000
  1. Power Off: Turn off the device.
  2. Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
  3. Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
  4. Power Off Again: Turn off the device once more.
  5. Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
  6. Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
4/20/2024 8:57:52 PM • Audio Players &... • Answered on Apr 20, 2024
Panasonic SA-PM250 CD stereo system. Tune dab radio sa pm250?
this model SA rather than SC seems to be a Middle East model. The SC version doesn't have DAB. https://www.google.com/search?q=panasonic+sa-pm250+instruction+manual ..
4/20/2024 5:59:04 PM • Audio Players &... • Answered on Apr 20, 2024
Setting time on fmdott085 V398
All questions need clear 'make model (what it is)' first 3 words. https://www.google.com/search?q=fmdott085+V398 ..
4/17/2024 4:54:26 PM • Audio Players &... • Answered on Apr 17, 2024
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS. Question moved from Cars and Trucks category. Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries. How long is the warranty on AfterShokz? While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase. Jan 11, 2019
How To File A Warranty Claim For Your SHOKZ Headphones
https://www.google.com/search?q=Openfit+Shokz+battery+replacement ..
4/16/2024 4:58:24 PM • Audio Players &... • Answered on Apr 16, 2024
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first. But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
4/16/2024 5:57:29 AM • Audio Players &... • Answered on Apr 16, 2024
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
4/10/2024 6:11:44 AM • Audio Players &... • Answered on Apr 10, 2024
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
4/9/2024 1:32:47 PM • Audio Players &... • Answered on Apr 09, 2024
Pyramid XPA-100 Amplifier Logo
2 questions posted
Top Pyramid Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Pyramid Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Pyramid Audio Players & Recorders
Most Popular Question
fan loud
  • Audio Players & Recorders
