Edu-Science Edu Science Do & Discover Mind Blowing Science Kit Logo
Posted on Feb 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do & Discover Rock Tumbler by edu science is leaking badly
Rock Tumbler is leaking badly
Anonymous
Level 2:
Champion:
New Friend:
  • Expert 217 Answers
  • Posted on Mar 03, 2013
Anonymous
Expert
Level 2:
Champion:
New Friend:
Answers
217
Questions
15
Helped
108163
Points
371
Use vasoline to seal the leaks, it should work
2answers
Why did the rock collector like his collection of metamorphic rocks?
Because the washing up fell over due to his use of tectonic plates
Where can I find an instruction manual for edu science land and sky 360 (50mm refractor) telecope?
Check the manufacture. If you didn't have it too long take it back to T...R...US and go elsewhere and by a good scope.
I have a edu-science telescope that connects to the internet and is powered so that it rotates and finds the stars for you. I have lost the disk that belongs to the telescope. It has Dia=76mm & F=700mm...
Contact Toys R US that sell this telescope-- or use either www.stellarium to control the scope.
www.stellarium.org
The disk is not actually needed it is just a planetarium software like Stellarium. All the goto controls are inside the hand controller.
2helpful
We have a rock tumbler and have lost the instructions. How long are we to tumble each stage? I assume that the sand goes inside the tumbler with the rocks. We need some directions.
Fill the barrel most of the way with stones, add coarse grit, add enough water to just cover the stones and then clean where the lid seals carefully. Seal it up and run it for a week, dump everything into a colander and rinse. Don't run that mud down your drain because it will plug it mightily, run it outside.
Do the same process with the fine grit, run it for another week and rinse and admire.
lp
Where can i find a set of instructions for our edu science rock tumbler.
I used to have exactly that same rock tumbler. I have a bunch of polished rocks out in my garden that the kids and I made with that thing.
I don't have the instructions, but there are some perfectly great generic instructions on the geology.com web site: http://geology.com/rock-tumbler/rock-tumbler-instructions.shtml
I used these directions with great success.
28helpful
2answers
We lost the creatology rock tumbler instruction manual and cant do anything with out it
Hi, We got the same tumbler this Christmas. You might be able to get an manual from [email protected]
To get started though, Step 1 takes 2-4 days, step 2 4-7 days, step 3 2hrs, step 4 2 hrs.
To start day 1
1) rinse stones with water and fill barrel with no more than 8 oz of stones
2) Add step 1 course Grinding Powder
3) Add enough water to cover stones
4) tighten (snugly) cap on barrel to prevent leaking
5) Be sure barrel is clean & dry. Fit barrel into tumbler (fits correctly only in 1 direction). Cover barrel with safety dome.
6) Attach DC plug to tumbler and plug in.
7) Push on/off button
8) Push # of days button timer.
Extras
They suggest using a lubricant on the inside rim of lid to help removal.
Once you start the tumbling do not turn it off and leave it off - It will harden like cement inside the barrel.
It is loud so place it on a towel to help reduce noise and put it where it won't bother anyone.
Good Luck and Have Fun
Dec 26, 2010 • Toys
3helpful
I need a manual for edu-toys microscope
I EDU science microscope 600x and it won't turn on it won't work out me there's no instruction manual how do I do this
Top Edu-Science Science & Laboratory Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Collins Mccoy
Collins Mccoy
Are you an Edu-Science Science and Laboratory Expert? Answer questions, earn points and help others
