Sharp EL-1197PII Calculator Logo
Posted on Feb 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you set the tax rate
I don't know how to set the GST tax rate so I just hit tax+ or tax- to break out the GST.
  • 1 more comment
  • Anonymous Mar 13, 2014
    change GST rate
    How to change GST rate for Casio FR-2650T
Harisk Karameh
Level 2:
  • Expert 68 Answers
  • Posted on Feb 16, 2009
Harisk Karameh
Expert
Level 2:
Answers
68
Questions
0
Helped
25138
Points
169
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Hello we have recently purchased a electronic cash register SE-S300 casio we have accidenlty put it on the Australian GST mode and we can not get it back to english pounds. what code do we use to get...
I haven't used that setting before. If you have fully activated it, you should see many changes along with the dollar sign such as tax break down and GST receipt message. If so, I think this should work:
Turn key to X mode 01012001 SUBTOTAL SUBTOTAL
If the only change is the currency symbol, don't do the above, just let me know.
_______________________________________
If anyone needs more information, the Casio SE-S300 manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
I have casio pcr-t275 i want to know, how to do gst & pst tax separatly
It depends on how it is set up currently. You need to set two tax rates (tax1 and tax 2) in the machine, then link them to various departments. It is best to print out the tax settings first, then copy the status when setting the second tax. This is described in the manual. If you need one, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T275_users_manual.html
Once you have the manual, I can work you through it.
How do you set the tax rate (GST) in the Casio 140cr cash register?
1) Turn Switch key to PGM
2) press the TAX PGM key
3) enter tax rate ( example 6% is 6 , 5.75% enter 5.75
4) press the Dept key you want that tax rate set too .
5) repeat steps 3&4 for diffrent tax rates or depts.
6) press Sub total key to end programming
http://www.casio4business.com/sa/products/downloads/manuals/140CR_user_English.pdf ====== USER manual
1helpful
Hi, I have a Casio PCR-T465. I'm a little stumped as how to change the GST & PST to just HST of 13%. I was wondering if you could help me out. Thanks!
You need to set one rate for HST and change your department links to look at the single rate. Which tax numbers do you use at the moment? E.g. tax1 PST, tax2, GST. We need to know which tax numbers are allocated for which tax types.
If anyone needs a manual for a Casio PCR-T465 cash register, http://the-checkout-tech.com/manuals/cashregisters/Casio_PCR-T465_users_and_programming_manual.html
41helpful
How do I set the GST/VAT tax rate on a Casio WM220T calculator
This works on several different casio calculators
Press AC butoon
Press AND HOLD % /Rate Set button for 2 to 3 seconds - This is important
Press Tax+ button
Input the tax rate you want eg: 12½% = 12.5
Press the % /Rate set button again
Voila
15helpful
4answers
Casio PCR-T275 Tax settings
Comment je programme les taxe de tvq 5% et tps 7.5 % pour le québec sur ma caisse casio pcr-t275
7helpful
2answers
Programming of the casio pcr-t275
Hi program the taxes like the book says but fix the gst rate, then go to program mode and push 1 subtotal, then push t/s1(taxtable 1 which is gst) and the dept number you want to use, then subtotal and cash and that will be the dept you will use for just gst. Hope I'm making sense. Took me forever to figure this out.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
