SOURCE: The fault light immediately comes on my Crown XLS
Hi try disconnecting the speaker outs and turn off bridge (if its on) If it doesnt work still, then suggest direct to a crown agent. The amp has a 3 year no fault warranty. Hopefully its still in!
All the best
SOURCE: left channel not operating on crown xls 602
Every time i have this prob i've blown that channel. In my case i,ve had dodgy connections to my speakers and if it is operating with high voltage rails they don't take much to blow.
Take off cover and you will no doubt find fuses somewhere blown. If it has come from speakers you prob done the amp but if not you might be lucky and just have to replace a single fuse or so.Good luck,Paul
SOURCE: There is a red light shinig inside my CROWN XLS
Lots of electronics have lights (LEDs) that turn on when they are plugged it. Most people just don't notice them. If it is working properly, then the light is normal.
SOURCE: No power to Crown XLS 602 Amplifier
Hi...
There may be some internal fuses on that unit.
You can open it by taking the cover off and looking for fuses and discolored parts.
It may have a thermal fuse on the power transformer which then will require service
Check the web for service people in the UK
SOURCE: my crown 602 xls tripped a breaker, I reset
They use a breaker instead of a fuse. CONDITION: No power to the amplifier. POSSIBLE REASON: • The amplifier's Power switch is off. • The amplifier is not plugged into the power receptacle. • The amplifier's high-voltage power supply circuit breaker has tripped. Verify that the AC mains voltage is correct, then press the Circuit Breaker button on the back panel. Take it to the ER.
http://www.retrevo.com/support/Crown-XLS-602-Amps-manual/id/19050ci763/t/2/
CONDITION: No
POSSIBLE REASON:
Take it to the ER.
