20 Most Recent Crown CE1000 2-Channel Amplifier Questions & Answers
0answers
2answers
3055 transistor short
How do you know it is shorted. What is the full part number, that number is on transistors, MOSFETS and a few other things.
10/28/2015 11:52:16 PM • Crown CE1000... • Answered on Oct 28, 2015
Where do the two white wires, one blue, one black, hook up
I have no schematic so I cannot help you. Do you know somebody that has one, if so take a picture of it. Normally if I am not super familiar with something I take pictures before taking apart.
10/24/2015 12:30:53 AM • Crown CE1000... • Answered on Oct 24, 2015
Schematic diagram ce1000 crown amp
2/9/2015 3:11:18 PM • Crown CE1000... • Answered on Feb 09, 2015
2answers
Bridged
setup of bridge mono mode:-1-turn your amplifier off.2-connect input wiring to channel(1) input--3-connect speaker across positive outputs terminals-do not use negative terminal when amplifier is operating in bridge mono mode.4-turn down (fully counter clockwise)of channel (2).
12/16/2014 8:37:01 PM • Crown CE1000... • Answered on Dec 16, 2014
2answers
Without any audio source or speakers on output
It's very likely that the main power amp section has a faulty part on it that is presumably causing an overload. You should check the devices on the main heat sink of the amp section.
12/16/2014 8:35:33 PM • Crown CE1000... • Answered on Dec 16, 2014
2answers
Will our Crown CE1000A amp
Check to make sure the channels are bridged so both A & B use the same input signal.
12/16/2014 8:32:37 PM • Crown CE1000... • Answered on Dec 16, 2014
Why fan stop working
If the fan is not working, it could be the fan itself, or it could be missing the voltage to drive it. I wouldn't use the amp with this condition, as you may cause output failure. If you need more information, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
12/6/2014 3:05:18 AM • Crown CE1000... • Answered on Dec 06, 2014
2 speakers and 1 powered sub
The red and black connectors are the right (red) and left channels for the speakers, so they should connect. However the sub needs a single RCA type phono socket, which should be marked "sub" etc. If it hasn't got one of them you will have problems connecting the powered sub.
6/15/2013 12:38:15 AM • Crown CE1000... • Answered on Jun 15, 2013
I NEED SCHEMATIC DIAGRAM OF CE1000
Hi,I think this is what you wanted.Thanks,gylacz
12/5/2012 8:35:51 AM • Crown CE1000... • Answered on Dec 05, 2012
0answers
I need circuit diagram for amplifier
http://elektrotanya.com/crown_ce1000_ce2000_ce_series.pdf/download.htmlclick on the download link on the right next to the manual frontpage picture
12/2/2011 8:01:47 PM • Crown CE1000... • Answered on Dec 02, 2011
2answers
I recently dropped my amp after a gig and once I
I am a musician myself (classic rock band) I too have a crown two Chanel amp , only difference is ours is a 3000. Well don!t feel bad. I had dropped mine more than once and your right, when you turn it on you hear two clicks, one for each side, those are relays that trigger the power to come on and like warm up. I dropped mine one time and both sides were not clicking at all, so I took it apart ( lid off, unplugged of course) located the relays which were pretty easy to find as they were the first switch from where the internal power plug comes in, I moved them around, got lucky, they got loose from when I dropped. Then happened again by a helper, and this time no help. Went to guitar center and they took unit and replaced them, about 40 bucks. That was a couple years ago. Point of my story, this problem seems as mine, and I believe it is going to be a loose or broken relay for that side chanel. Thanks mike, hope this helps.
9/1/2011 5:13:48 AM • Crown CE1000... • Answered on Sep 01, 2011
How amplifiers works
Use equalizer
7/13/2011 10:17:21 AM • Crown CE1000... • Answered on Jul 13, 2011
2answers
The left channel of the
make sure the olug in is very tight and the wiring has a solid connection. If not feedback of this sort is very common
6/22/2011 4:26:23 AM • Crown CE1000... • Answered on Jun 22, 2011
It clips as soon as
I actually had a similar problem with a couple of the 2000w version (band was running two 2000w crowns PLUS another 500w JVC for the sub). We replaced the reset button, and that did the trick, until they completely wore out a few years after that (constant use is harsh on these...).
Hope that helps! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
2/12/2011 2:15:02 AM • Crown CE1000... • Answered on Feb 12, 2011
How many amps ?
To determine the current draw (assuming near-unity power factor), divide the input power wattage printed on the back of the amplifier by the line voltage.
11/18/2010 7:43:21 AM • Crown CE1000... • Answered on Nov 18, 2010
Crown CE1000 2-Channel Amplifier Logo
69 questions posted
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Mike Cairns
Mike Cairns
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Crown Audio Players & Recorders
Most Popular Question
recently dropped amp after gig once
  • Audio Players & Recorders
