Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I would suggest removing your heart rate grips and inspecting the contact leads for rust or any other corrosion. This is very commonly an issue and can be resolved by either cleaning the contacts or simply replacing the parts. Using the following link, and your serial number, you should be able to find the contact grips if you end up needing them.
Repair Parts for LifeFitness 95T 95Ti 95Te Treadmills Midline SPORTSMITH...
SOURCE: heart rate monitor chest band not working with Life Fitness 9500H
This mean that you unit is not equiped with a receiver inside the treadmill. Some models that was an option. Polar is the only brand that works with Lifefitness. You may have a bad upper display board. You can buy a replacement for a small amount of money.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Enter the diagnostic menu and ensure the "telemetry" option is enabled in the managers config menu.
SOURCE: life fitness 95ti belt moving to one side any way of correcting
If the walking belt has shifted to the left, use the Allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left rear roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centred.
Please see here for some Life fitness spares:
http://www.partsfortreadmill.com/catalogsearch/result/?q=Life+fitness
and here for dismantling your treadmill and changing the belt:
http://www.treadmillsrepair.co.uk/2013/12/belt-for-treadmill-replacement-and.html
u may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions
You may have started wearing a Polar F11 Fitness heart rate monitor to help you keep track of your pulse during cardiovascular exercise. The monitor consists of a strap with electrodes that you attach to your chest, which transmit heart rate data to a receiver worn on your wrist like a watch. The wrist unit stores data and settings that you can customize, such as your weight, height and target heart rates. However, you may wish to reset the unit and start over with new settings. You can reset your Polar F11 by following a few easy steps.
Instructions:
