Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Posted on Feb 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Door handle is loose
Kenmore elite (model #79577243600) refrig and the handle has become loose and has pulled off it's post. How do I reattach and tighten?
thanks
  • Anonymous Feb 15, 2009
    The door handle is partially attached. How do I press it back into place?
Affordable Appliance Parts
Level 2:
Novelist:
  • Expert 117 Answers
  • Posted on Feb 13, 2009
Expert
Level 2:
Novelist:
Answers
117
Questions
0
Helped
59209
Points
312
If my memory serves me correctly, you should see two posts attached to the refrigerator door right now. The handle slips over these posts and if you look closely there is a little hole in the handle where you would insert a allen key wrench to tighten the little screw against the post protruding from the door itself. With the door handle in your hand, properly match up the correct allen wrench to fit the allen screw very snug. Realign the door handle on the protrucing posts and tighten. Once finished, you should have a tight fitting door handle again. Let us know if we can help further.....Eric
How to tighten a door handle on a frididaire refrig model #FFHS2622Mw0
The door handle screws are located beneath the door gaskets, simply pull the gaskets loose from the frame and tighten screws then reattach the gaskets.
1helpful
Our kenmore elite he3 belt and spring came off..my husband replaced it and upon turning the machine on, the power switch just dinged..no lights...and the door is locked! We tried unplugging for an hr..he...
Sounds lik a loose connection... E70
what you need to do if you are comfoable. ( best with certified spark tbh) is unplug machine nd check all connection internally are secure with no 'pulled' wires or pulled electrical connector clips. This may have become loose when replacing bebelt good luck
Kenmore elite dishwasher model 665.16493300 door falls to floor when opening
Door springs are located at the left and right side of the door bottom. You will have to pull the unit a few inches from the installed location to see them. If broken, replace. If one slipped off, reattach.
Freezer handle falls off on one side , kenmore elite - pull drawer freezer
Mine does that too. I've simply accepted the fact the the screw holding the handle on just loosens over time. Periodically, when I feel the handle becoming loose, I tighten it with an allen wrench and go on.
7helpful
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
1helpful
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
2helpful
Sears trio elite ...french doors with bottom freezer...right side loose on freezer door handle...thanks
I have the same refrig. After taking the freezer basket hinges off, thinking I had to take the whole door a part to access the screws for the handle...my husband figured that the handle probably slides off...and yes that is just what it does!
Push the handle in a bit and then slide to the right. It takes a little bit of effort but that handle will come right off. Then you can tighten the screw that holds the clip in place. Then you line the handle back up to the clips, and slide to the left. Good Luck!
2answers
596.73502200 Refrig
easy, get the model number from inside the frig. go to sears .com put your model number in and you will get the whole diagram of your frig. and how the handles come off,i'am thinking if you don't see the screws you have a panel over them that will slide up or down to let you get to the screws ,let me know how you do-mike
Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
1helpful
Kenmore Elite smartheat9 model110.85862400
If i remember correctlysix screws on inside of door then the plastic frame comes off and two screws to take off door handle that should set u straight its the six small screws
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
