Go here for manual > http://www.breitling.com/user-manuals/en
SOURCE: breitling watch winder rotations requirments
The watch should last 36 hours from fully wound. If your wearing the watch and using a watch winder and its still stopping, you have a problem with the mechanism. Get it serviced. (its probably just a clean and oil req'd)
SOURCE: how do you set the chrono dials on a breitling
Unscrew the crown, (it's water resistant) pull the crown out, 1st click sets mins. All the way out sets seconds.
Push back in when done & screw crown down to keep it watertight.
Do NOT overtighten.
SOURCE: I've got a breitling superocean chrono and want to
Keep in mind that I dont have the watch in my hand... :-)
If this is an authentic Breitling...
You should have 2 buttons on the right with the crown between them. The crown screws down so you need to unscrew it before you attempt to set! Once unscrewed with gentle pressure pull the crown out. There should be 2 clicks, pull to 2nd click or furthest distance from case. That should be the time setting mode. Turn clockwise until the date changes then set your time. To change the date push back to the 1st click and that should be the date set mode. One direction will be for day and the opposite will be date. I believe that if you pull the crown back to 2nd click and push your buttons that should change the subdials for chrono. You might need to push both buttons at the same time.
Ive set Breitlings before but they arent a common watch we see. Most people dont use the Chrono so if the directions dont work for setting those then I wouldnt worry too much about it! Not many people are going to notice those. :-) Also be so very careful if its a real Breitling as they are a very expensive to fix! :-)
***DONT FORGET TO SCREW THE CROWN BACK DOWN OR YOU WILL GET WATER INSIDE THE WATCH!***
SOURCE: Please can you tell me
Hi Donald.
Breitling does not release manuals in PDF format.
To request a manual you need to contact BREITLING SA, P.O.Box 1132, CH 2540 Grenchen, Switzerland. Write them a letter reporting the watch model number.
Alternatively locate the nearest maintenance center, click on maintenance center option on the left bar in this page.
Some info can also be obtained from the Breitling Club, in Israel. That is the only website listing manuals, the website members manually traduced several instructions books. Try contacting them. Instructions are very simiar to Chronomat and other Chronos . Here page.
Regards.
Ginko.
BREITLING USA INC.
HANGAR 7
206 DANBURY ROAD
WILTON, CT 06897
[email protected]
Tel: +1-800-641-7343
Tel: +1-203-762-1180
Fax: +1-203-762-1178
In Switzerland:
BREITLING SA
P.O. BOX 1132
2540 GRENCHEN - SUISSE
Tel: +41 32 654 54 54
Fax: +41 32 654 54 00
One other note.
The COSC number generally refers to the movement number not the case number.
Inspect the hang tags that came with the watch.. the movement number may be referred to on one of them... or to the COSC certificate.
Otherwise the only way the movement number can be viewed is to remove the back.
Watches have several numbers.. reference and serial.
A - Stainless Steel
13 - Caliber
3 - Certified
40 - Model (Super Ocean)
The case will have a number the movement and the bracelet.. the crystal etc etc.
When you have the watch serviced.. have them write the movement number down for you.. for comparison.
