My htc radar is stuck on white start up screen,so i kept my finger on off button,it turns off then immediately turns back on to the white start up screen on its own.
The problem was with my motherboard, it was exchanged and everything got better since then :)The problem was with my motherboard, it was exchanged and everything got better since then :)
You can't post conmments that contain an email address.
Hi Mike, The link below is a YouTube video showing how to fix your phone, Also there's video's down the right side of the link that may help as well, BUT if that's not the issue then try the other links for white screen....CHEERS.. How To fix any Android Phone Tablet that won turn on
Hi you can easily unlock your htc radar phone by using unlock code. If you need unlock code you can visit this site Prounlocking.com here you can get the code and unlock your mobile easily. To get the code you have to mentioned which country is locked now,network provider and imei number. Then they send unlock code through email Prounlocking.com
Hold down power button for about 30 seconds (or until phone recognizes power off), let it shut down.Afterwards, hold power button down maybe 10 seconds, release and let it reboot. If it performs normally, great. If not, check the following page:
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET:Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware:
1) Turn off phone
2) While holding down both the Up/Down Volume buttons, turn unit on
3) Keep holding down the volume buttons until white screen appears
4) Press the Down Volume button to reset to factory defaults.
5) Restart phone
Resetting the phone deletes
all data, including downloaded applications, and resets the phone back
to its initial state. Press HOME > MENU, then tap Settings >
Security > Factory data reset. On the Factory data reset screen, tap
Reset phone and then tap Erase everything. To reset the phone using
phone buttons, with the phone turned off, press and hold the HOME, END
CALL/POWER, and BACK buttons. The reset process will start after a few
seconds
To get to the calibraition screen, turn the nuvi off. While
holding your finger anywhere on the screen, slide the Nuvi power switch to ON - then
immediately slide the button to the LOCK position. Do not lift your finger from the screen UNTIL you see the calibration screen (about 15 to 20 seconds).
Use a pencil or other narrow tipped device to touch the calibration points on the screen instead of your fingers for an accurate calibration.
Please rate this reply if found to be helpful - good luck!
1. Plug in controller
2. Have system in standby mode (red light)
3. Hold down power button for a full cycle (will turn on and back off again)
4. Hold power button again will hear 2 single beeps then a double beep.
5. As soon as you hear the double beep immediately remove your finger from the power button.
6. Hit the PS button on controller when it tells you to
7. Go to ONLY option 3 (restore)
8. WARNING: select any other option and you can wipe out everything ONLY USE OPTION 3
9. Follow on screen prompts
Try this and get back with me, I will look into it for you.
