Bought my Shark G1400Z iron about a year ago. The iron caught on fire. Luckly I was only out of the room for a few seconds. What can be done about this?
Check the power connection, the power cord to the heating coil. If there is no suppy then check the bimetal contact of the temperature setting switch, if voltage comes to coil without heating, the coil can be open .
You will have to use a multimeter in Ohms range to check the continuity of the coil.
Have to decide is coil is open about the cost of coil to that of a new iron.
Generally, the lights on the right flash until the desired temperature is reached. When they stop flashing it means the iron has heated to the temp. that you selected. I'm having trouble with mine now, also, so I can't diagnose.
1: Make sure there's enough water in the tank if the iron won't steam.
Fill
the tank up . 2:Check that the iron is set to a steam setting. Some
of the settings are
dry and won't create steam. 3:Set the temperature dial to the shaded
setting which represents steam.
You'll see a little dark cloud-type icon with raindrops as opposed to a
white cloud with a stripe through it. The dark cloud represents moisture
(steam), and the white cloud with the stripe through it represents no
steam. 4:Allow the iron to heat up for a while and to emit steam for a
couple of
minutes while pressing the extra-long burst button a few times. That
should get rid of any impurities which can cause blockages. Try this if
the iron hasn't been used for a while and steaming is intermittent. 5:Iron
horizontally. Steam is only generated when the iron is horizontal. 6:Use
the maximum steam setting when the iron is set to its maximum
temperature setting. 7:Let the iron get to a high temperature before
expecting steam. If the
soleplate isn't hot enough, the water won't turn to steam and will in
fact drip, spit or leak from the soleplate. Some Rowenta irons have an
anti-drip system, which will turn off the steam when ironing at a low
temperatures. Turn the temperature up, if needed.
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill
the tank up . 2:Check that the iron is set to a steam setting. Some of the settings are
dry and won't create steam. 3:Set the temperature dial to the shaded setting which represents steam.
steam. 4:Allow the iron to heat up for a while and to emit steam for a couple of
the iron hasn't been used for a while and steaming is intermittent. 5:Iron horizontally. Steam is only generated when the iron is horizontal. 6:Use the maximum steam setting when the iron is set to its maximum
temperature setting. 7:Let the iron get to a high temperature before expecting steam. If the
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
