The regulator on our stove leaks. Is there any way to fix this or do we need to replace the regulator? And where can we find the parts to fix it or where can we purchase a new one?
Just where the regulator attaches to the burner there is a small nut that may be loose. If you look closely at this and turn the regulator (stove off and hose detached!) you may see the nut hat turns easily. Tighten it and make sure the regulator does not rotate too freely, but still turns to adjust when attached to the hose or the smaller gas cartridge, if using that. Test carefully after this.
