There is no data provided on artist, sond, etc. on FM tuner. Only the name of the radio station appear (ex. NRJ or Rouge FM). The radio in my other car works well and all the informations appear. What can i do for this ?
SOURCE: Can I use avh-p6500dvd radio with avh-p6600dvd brain.
hi i have the same unit but i dont need a brain for mine what is it your needing the brain for
SOURCE: AVH-P6600DVD
You have it wired wrong. The red wire goes to the key switch and the yellow wire goes to the battery or a constant hot wire.
Good Luck and please rate
SOURCE: how do u bypass parking
ground the parking brake wire or tie into a toggle switch or wire a relay into the antenna acc parking brake
SOURCE: Pioneer AVH P6500DVD Tuner Failed
sounds like the antena plug on the back of the unit came out pull out an check
SOURCE: I have a AVH P3200BT and when I try to play a DVD
Are you trying to view while driving if so the unit is not supposed to play that way. If you are parked you need to engage the parking brake. Its illegal to have video showing while moving. Most installers know how to do it but arent supposed to do it because they can get sued for setting it up that way in your car if you get in an accident
