Model EC-510 - the tank gets to about 25 lbs then pressure leaks from the control knob. I understand you can fix this by replacing the o-ring in the control knob???
SOURCE: oil covering pancake and pressure adjustments
Typically on the inside cover of the electical box it will illustrate the cut-in/cut-out controls. There should also be a fill port above the pump end of the compressor. Do you have a sight glass on the side of the compressor *(around the area of the leaking oil) usually if its coming out its due to overfilling or tipping over of the compressor.
SOURCE: tank will not build pressure beyond 25 lbs. Just runs
IS YOUR AIR FILTER CLOGGED. SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY. THEY ARE MOST LIKELY REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES. MAKE SURE THEY ARE CLOSING ALL THE WAY (NOT CARBONED UP). DID YOU REMOVE THE HEAD AND DID YOU PUT BACK LIKE YOU FOUND IT - NOT TURNED OR FLIPPED OVER. SEE IF YOUR FINGER WILL GET SUCKED UP TO THE INTAKE HOLE.
SOURCE: 25 gal horizontal craftsman air compressor is leak...
Unloader valve probably needs to be adjusted. Should be two jam nuts holding the unloader to the pressure switch. Loosen the jam nuts and adjust the unloader slightly away from the lever. Tighten the jam nuts and try it again.
SOURCE: Mastercraft compressor - one pancake type tank ... need pressure
You do not need to use factory replacement switch. Mos t universal pressure switches are set to shut off at 120-130 psi. You will need to check the placement of the unloader valve (1/4 line from check valve) and the quantity of ports as some switches have only one port and others have 3-4. Check ebay for good match and low price. Good Luck
Can't anyone answer this query
