20 Most Recent Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Questions & Answers
You may have to order it directly from Clarke.
Clarke Power... | Answered on Sep 25, 2015
need to replace pressure switch as the leak is a worn needle valve assembly. it usually unloads from there when the machine stops
Clarke Power... | Answered on Jul 08, 2015
sounds as if windings in motor are about to fail or could be faulty overload switch
Clarke Power... | Answered on Oct 16, 2014
sounds like motor requires new capacitor to be fitted as this creates rotating field in the motor
replacement will be required to prevent overheating of the pump unit
in uk machine mart are distributers
they usually pull on and off anyway replace if required if not use pliers to turn knurled nut
capacitor problem not splitting phase sufficently
in the uk machine mart is distributer for clarke machines
It is normal for there to be a hiss from the pressure switch for a second when the unit stops, this allow any pressure in the line to be dissipated so next time the unit starts it doesn't have a pressure to start against. If it is constantly leaking it will be a problem with the non return valve. It is normally a brass fitting on the tank that the compressor pipe goes to. It may just have a bit of debris not allowing it to close properly, You need to drain down all air and remove the cap on the brass fitting, there should be a rubber shuttle with a spring behind, if it is hard an cracked it will need replacing or it may just need a clean.
Hope this helps,
James
Clarke Power... | Answered on May 22, 2014
problem same as your compressor usually problems in the piston, where it cannot compress air with strong, usually the ring piston is leak.
Clarke Power... | Answered on Apr 11, 2014
This company in liquidation in the US, however many of the same compressors are available in the UK re-branded with different model numbers/names (alpha name instead). Go down the list opening manuals until you find similar looking parts. You may find same pump/motor components on a different tank, however use manual information as needed. China made compressor as yours will be sold by many different retailers under different names. Look on ebay first "searching pancake" compressor for likeness. The manuals listed below should clue you in. Good luck.
http://www.clarkeservice.co.uk/product_manuals/air_compressors.shtml
Clarke Power... | Answered on Mar 28, 2014
Capacitor, check and see if the capacitor is ok
Clarke Power... | Answered on Dec 02, 2013
Clarke Power Products Inc AC2001 2HP 4 Gallon Pancake Tank Compressor Logo
92 questions posted
Top Clarke Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
View Most Popular
  • Clarke Air Tools & Compressors
Most Popular Question
need capacitor air compressor its
  • Air Tools & Compressors
